Output Speed Sensor Location
Old 06-09-2010, 08:12 PM
DanDMan's Avatar
DanDMan
DanDMan is offline
Just to host the images onsite here are the pics again:
Attached Thumbnails  Output Speed Sensor Location-rearsensor.jpg    Output Speed Sensor Location-outputspeedsensor.jpg
Old 06-30-2010, 01:04 PM
dpixley's Avatar
dpixley
dpixley is offline
Default '98 5.2 4x4
Would the ourput speed senor be located in the same place on a '98? Local shop wants $72.86 for the part and 69.97 for labor, total $142.83. Trying to save a few bucks.
Thanks for any help. The pics are great.
Don
Old 06-30-2010, 01:27 PM
I think on the 98's, the VSS is the sensor mounted on the rear axle. One or two bolts, and a wiring harness connector. Can change it in your driveway in less than ten minutes.
Old 06-30-2010, 03:50 PM
dpixley's Avatar
dpixley
dpixley is offline
Default Output Speed Sensor
I've replaced the sensor on the rear differential. I need to replace the output speed sensor on the transmission. Need to know where it's located. Thanks.
Old 06-30-2010, 06:35 PM
dpixley's Avatar
dpixley
dpixley is offline
Default Output speed sensor
Found it. How much tranny fluid will come out when I take out the sensor? Thanks.
Old 07-06-2010, 03:29 AM
ssnoogins187's Avatar
ssnoogins187
ssnoogins187 is offline
i have a 1998 dodge ram 1500 4x4 cant find output sensor not the rear dif i need a pic if it possable NEED HELP!!!!!!!!!!!!!
Old 07-06-2010, 08:34 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
98 only has one on the rear diff. They do not use one on the tailshaft.
Old 07-06-2010, 09:03 AM
Maxx_Magnum's Avatar
Maxx_Magnum
Maxx_Magnum is offline
I'll vouch for that, I just recently went looking for mine and it's in the rear end, not on the tranny. Mine's a 98 also
Old 08-27-2010, 12:23 PM
red94ram's Avatar
red94ram
red94ram is offline
I am trying to find the output speed sensor on my 1994 1500. I found a sensor on my trans (driver's side just above the linkages) that looks similar to the part I just bought at Autozone, but it does not look exactly the same.
Here is what I bought:
The sensor that I am looking at on my truck looks like I would have to drop the pan to remove it. The new one appears to be installed without removing the pan.
The plug connector on the new part looks like it would fit the plug from my truck, except one of the slots is backwards (ridge instead of a slot).
Does the pic by DanDMan apply to the 1994? I am still trying to determine if I have found the location of the output speed sensor. Thanks.
Old 09-09-2010, 11:12 AM
fflarry's Avatar
fflarry
fflarry is offline
Question help
I have a 99 dodge ram / 4x4/5.9 gas/1500
the abs light came on__ parking brake light came on /speedometer now doesn't work/won't shift into overdrive.
can anybody tell me which sensor it would be & is there a way to test senor?
Quick Reply: Output Speed Sensor Location
