Fuel Pump/Auto Shutdown relay HELP!!!!
Old 04-20-2008, 11:50 PM
BlueonBlack01's Avatar
BlueonBlack01
BlueonBlack01 is offline
Default Fuel Pump/Auto Shutdown relay HELP!!!!
I have an 01 Ram 1500 4x4 5.9L 126k miles. Today I ran out of gasand now It Will not start![:@] It is giving me 2 codes 1388 & 1389 "Auto Shutdown (ASD) Relay Control Circuit" and "No Auto Shutdown (ASD) Relay Output Voltage At PCM"I can clear the codes but as soon asI try and start it againthe codes come back up! Is the fuel pump bad??And What do these codes mean in simpler terms?
I just got the truck a week ago so I am not very famaliar w/ any of this yet.
Thanks
Old 04-21-2008, 12:32 AM
rabbler's Avatar
rabbler
rabbler is offline
Default RE: Fuel Pump/Auto Shutdown relay HELP!!!!
In the under hood fuse box swap the ASD and horn relays.
See if the horn works
Check all the fuses under hood too
See if it starts
Old 04-21-2008, 12:40 AM
BlueonBlack01
I just tried that and the horn woked but it still wount start.[:@]All the fuses look fine.
Old 04-21-2008, 12:44 AM
BlueonBlack01
I have a Hypertech Max Energy program in it, Could that have any thing to do with this??
Old 04-21-2008, 12:47 AM
BlueonBlack01
Ok! I know I'm getting gas cause I checked the Fuel test port on the fuel rail.
Old 08-23-2008, 02:28 PM
lolide's Avatar
lolide
lolide is offline
Junior Member
Default 2000 Dodge Caravan
I have a problem how do I know if it is my started that is bad the auto shutdown relay lit up. I looked under the hood and the ac clutch relay was clicking so I took it out I had the battery completely charged and then I bought a new relay thinking that is what it was but then the ASD relay kept clicking then you could also hear the clicking in the fuel pump wire if someone is out there that can lead me in the right direction then let me know.
Old 06-10-2009, 08:19 PM
yrevenge4's Avatar
yrevenge4
yrevenge4 is offline
Default Fuel Pump/Auto Shutdown Relay
Actually I had the same problem a short while back. THe battery is good but your not getting a good ground to the computer. Clean the battery posts/connecters with a baking soda wash. If the problem pesitts check the ground wires to the computer and chasis replace them if the are giving any ohm reading at all.
If this doesn't work then I have no other idea's.
Old 06-10-2009, 10:14 PM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
you can check the asd and the fuel relays at the same time. put one finger on both and have someone turn the truck on, you should feel a click when they're turned on and they have a soft off so you won't feel them turn off. i believe they're only supposed to click once. i know it ain't a fix but its progress.
Quick Reply: Fuel Pump/Auto Shutdown relay HELP!!!!
