Clicking noise under the hood
Old 04-11-2008, 05:42 PM
kurrz96ram's Avatar
kurrz96ram
kurrz96ram is offline
Default Clicking noise under the hood
Well like it asys I keep hearing a clicking under the hood. Almost sounds like an old school typewriter. It comes and goes and does'nt seem to have any rhyme or reason to happen. Thanks
Old 04-11-2008, 07:07 PM
citygasdude's Avatar
citygasdude
citygasdude is offline
Default RE: Clicking noise under the hood
I have a noise that sounds like that when I first start it up, goes away after it warms up, but cant hear it from inside the truck, only when walking past the front. I think it may be in my tensioner pulley, but its not a concern at this time.I dont seem to have any play in the pulley so maybe fan clutch? Keep me posted if you find out what it is!
Old 04-11-2008, 09:50 PM
Oaktree's Avatar
Oaktree
Oaktree is offline
I had 2 noises ,one was the pcv valve but that was more like a buzzing,haven't figured out what the clicking is. time to investigate.
Old 04-11-2008, 10:00 PM
mstephen89's Avatar
mstephen89
mstephen89 is offline
the clicking and squeeking when you warm up is usually a tensioner pulley or a idler pulley. You should remove the belt and spin them both and try to figure out what it is. If you do not fix them, they will eventually lock up and cause the belt to break, and cause the truck to run hot.
Old 04-12-2008, 03:21 PM
Silver_Dodge's Avatar
Silver_Dodge
Silver_Dodge is offline
Could be a lifter.
Old 04-12-2008, 04:24 PM
kurrz96ram's Avatar
kurrz96ram
The noise I have seems to happen when the truck is cold and warm. And when I hear it, it's almost like something is cycling.
Old 04-12-2008, 05:03 PM
Trey318's Avatar
Trey318
Trey318 is offline
Try listening to all of the bearings with a stethoscope. My dad has a special stethoscope with a pointed end for listening to specific areas.
Old 04-13-2008, 07:23 AM
v10power's Avatar
v10power
v10power is offline
I would look at the pulleys or the tensioner like perviously stated. If it sounds like its cycleing then maybe the AC compressor. Another bet would be the Lifters like previously stated. All of these are great areas to start and none of them require a great deal of diagnosis to rule out or in for that matter
Old 04-13-2008, 07:52 PM
kurrz96ram's Avatar
kurrz96ram
Yeah its the pulley on the ac comp. I popped the hood and started it and it started making the noise right away. Thanks guys.
Old 02-05-2018, 07:00 PM
Nancy Padgett's Avatar
Nancy Padgett
Nancy Padgett is offline
Question my durango relays are clicking & N light flashes when truck is off
my truck relays are clicking after i turn the engine off. also the neutral light flashes when this happens.
anyone have a clue what causes this?
Quick Reply: Clicking noise under the hood
