engine light code: P0441 Evaporative Emission Control System Incorrect Purge Flow
Old 04-09-2008, 06:16 AM
otherside's Avatar
otherside
otherside is offline
Default engine light code: P0441 Evaporative Emission Control System Incorrect Purge Flow
hey guys..
got the error code today...P0441 Evaporative Emission Control System Incorrect Purge Flow . does anyone knows what it means and what to do?
martin
Old 04-09-2008, 10:20 AM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Default RE: engine light code: P0441 Evaporative Emission Control System Incorrect Purge Flow
Probably a cracked line. Trace the lines from the engine compartment all the way back, pay very close attention around the cannister. You'll probably find a crack or split around a hose clamp. Easy repair to do yourself by either replacing a hose, silconing a crack or cutting a split end out and re-doing a clamp, depending on what you find.
This is VERY common...
Quick Reply: engine light code: P0441 Evaporative Emission Control System Incorrect Purge Flow
