bleeding coolant system
Old 04-06-2008, 11:00 PM
dirt_trac_racer_80jr's Avatar
dirt_trac_racer_80jr is offline
Default bleeding coolant system
so i just got the motor back in and running...but now i cant get the coolant system to bleed out ...it acts like it has alot of air in it ...it cant be the head gasket cause i just changed it ...is there sum kind of trick to gettin all the air out ...i also noticed that my overflow has a crack in it ...could this be the reason im having problems?
Old 04-06-2008, 11:24 PM
95to96transplantneon's Avatar
95to96transplantneon is offline
Default RE: bleeding coolant system
Ive allways just removed the cap while the car was cold and started it up squeeze the upper radiator hose everyonce and a while and it will burp itself out...
Old 04-07-2008, 01:01 AM
wat about the over flow container...at the end of the season i blew a headgasket so the coolant system was all water no antifreeze because i was replacing the water it lost when it steamed out ...when i parked it for the winter i added antifreeze to the radiator but forgot about the overflow tank ..so wat water was in it froze and cracked the plastic..it doesnt hold any water now....i know i need to replace it and i plan on doin it tomoro..but could i be gettin air from the crack thats in it ....
Old 04-07-2008, 12:04 PM
12 volt's Avatar
12 volt
12 volt is offline
could i be gettin air from the overflow tank crack
thats your problem. your looseing coolant and sucking in air
Old 04-07-2008, 12:34 PM
das2123's Avatar
das2123
das2123 is offline
^^^Agreed!
I leave the cap off and start the engine to let the air out also.
Old 12-23-2008, 09:49 AM
Mopar Madness 1's Avatar
Mopar Madness 1
Mopar Madness 1 is offline
On some of the older mopars like 383's,440's there was a bleeder located on the goose neck where the upper hose connected to the thermostat housing. What you would do is while the motor was running,You would open the bleeder and let the air out. On my 97 Chrysler LHS I have that bleeder but I'm not sure if the newer engines still have that option. I hope you can fix the trouble your having.
Quick Reply: bleeding coolant system
