Check engine light - code P0524 low oil pressure on 07 Ram 1500 Hemi
Old 04-04-2008, 09:02 AM
The BIG STEAK's Avatar
The BIG STEAK
The BIG STEAK is offline
Default Check engine light - code P0524 low oil pressure on 07 Ram 1500 Hemi
Hey People, Anyone ever get the check engine light code P0524 for low oil pressure? I have had it 3 times now since I got the truck new almost a year ago. It has 20000km, the oil level is good, oil just changed and the gauge on the dash reads a little over the half way point. When the CEL comes on, the truck has been running for about half an hour (fully warmed up) and idling in gear at the stop light. The freeze frame data on the code reader shows normal engine temp, RPM at about 650 and no other codes in memory. The truck engine management stays in closed loop mode too. Since I have a code reader, I just reset the light myself. Should I be overly concerned? Should I bring it to the dealer so that they can address this? Truck is running fineotherwise. ANY thoughts???
Thanks
STEAK
Old 05-16-2008, 03:37 PM
ewilsoniii's Avatar
ewilsoniii
ewilsoniii is offline
Default RE: Check engine light - code P0524 low oil pressure on 07 Ram 1500 Hemi
I have a 2007 Ram 1500 5.7 Hemi with 12735 miles. Mine has done it twice since having my oil changed this week at a Valvoline drive thru. They put in Synthetic 5W20(told me it was recommended - yeah cost more). I spoke with the Service Manager at my Dealer and he said the Synthetic oil can cause this because it is thinner. I am going to drain the Synthetic 5W20 this weekend and use regular 5W20, clear the code and see what happens. The Service Manager also said the next time I bring in the truck they will flash the PCM.
Old 06-14-2008, 04:34 PM
rick_s's Avatar
rick_s
rick_s is offline
I had this happen also, first time today. Wife reported Check Engine when she brought the truck
back. My Innova 3100 scanner can't read the Dodge OBD-II for whatever reason, but I was
able to get the code (P0524) via ElmScan. Due for an oil change anyways, so I'll try
switching from the synthetic we've been using and see if that helps. Same gage reading
in my case - a bit over half on the pressure gage, with the dipstick showing normal
oil level. I see on the 2008 Ram there is a TSB about this.
(can't help but editorialize: dealers gotta love CheckEngine :-) )
Old 06-15-2008, 11:21 AM
whiteonrice's Avatar
whiteonrice
whiteonrice is offline
Have the reflash done. It works. Don't waste your money draining the good oil out.
LoneStarHemiLover (03-11-2020)
Old 06-15-2008, 11:42 AM
daytona1680's Avatar
daytona1680
daytona1680 is offline
dont drain the synthetic, your service manager is dumb..I have seen alot of people who have had this problem, PCM just needs flashed.
Old 06-15-2008, 12:26 PM
RamSportBlue's Avatar
RamSportBlue
RamSportBlue is offline
rick_sCould you put a link to that recall, can't find it. My oil pressure sure move on the gauge. Highway/normal driving siiting just above Half way point. Idle at any time at the bottom of safe zone. Has done it since new. Two other friends with 07 don't do this so needs to be addressed at the dealer I guess.
Old 06-15-2008, 12:42 PM
rick_s's Avatar
rick_s
rick_s is offline
We were due for an oil change anyways, but it didn't help. I get P0524 immediately after I
reset the code. Truck goes into the dealer tomorrow AM, I'll ask them to reflash
when it's in the shop.
About the TSB I saw, here is the link:
http://db.theautochannel.com/db/DodgeReviews/safety.php
Scroll down the page to 2008 Dodge RAM 1500, you'll see the
bulletin there (1804407). I'm thinking the firmware probably didn't
change much between 2007/2008, so I have to wonder whether
this is a problem common to both years.
Question for the group. I remember going to the Dodge site and downloading the service
manual pdf when we first got the truck. Now when I go to the same page, it shuffles
me off to some site that wants me to pay for the manual. Was the "free" pdf manual
just a dream, or did Dodge decide to bang us DIY types? I mean, its really old to
have to pay for a CD copy of a manual, or worse, for the paper copy....
6/16/2008: a bit of followup after getting the truck back. The final diagnosis for
the P0524 code was "bad EGR valve". Does this make sense?
Old 06-15-2008, 12:53 PM
RamSportBlue
Thanks Alot Rick_S Truck goes in tomorrow as well will ask about recall/reflash.
Old 06-21-2008, 10:08 PM
whiteonrice
The TSB is 18-003-08 reprogram PCM and retest system. That cured my CEL problems.
Rick
Old 07-08-2008, 12:34 PM
yellowram's Avatar
yellowram
yellowram is offline
hey guys.i have one for you too! i have an 07 with about 12300 miles on it.my chech engine just came on again,i had it at the dealer last week and they told me that it was my oil pressure switch.they replaced it and all was good.but then my light came on again.i have been watching my oil pressure guage on the dash and have noticed that at stop lights it dropped to just below the center line on the guage.is this the same problem everyone else is having? i have been changing the oil every 3000 miles.thanks for any help!
Quick Reply: Check engine light - code P0524 low oil pressure on 07 Ram 1500 Hemi
