Limited Slip Differential Fluid?
Old 03-24-2008, 07:23 PM
NYPANAMA42's Avatar
NYPANAMA42
NYPANAMA42 is offline
Default Limited Slip Differential Fluid?
Got a question for you fella's. It's my understanding that the "Limited Slip Differential Fluid" is going for 18.00 per 4 fl oz.
Now, i try my best to make sure that my Ram gets all of the right fluids, but the way the economy is right now, if i can save a couple of bucks, and still purchase a quality fluid, i will do it.
Is this the only " Limited Slip Differential Fluid" we can use in our trucks? Can it purchased cheaper?
One other question. Is all Limited Slip Differential Fluids the same?
Old 03-24-2008, 08:23 PM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
Default RE: Limited Slip Differential Fluid?
I paid $8 for a seven ounce tube at Advance Auto Parts.
Old 03-24-2008, 08:32 PM
NYPANAMA42's Avatar
NYPANAMA42
ORIGINAL: MikeHTally
Thats a good price. according to the manual, when adding the fluid to the rear differential you need to add 5oz of this Differential fluid in addition to the 75W-90GL 5 gear lubricant. Now at the dealership, the bottles only come in one size. 4oz. and inorder to have 5oz, you need to purchase 2 bottles at 18.00 dollars a piece......
is the one you purchased from Advance Auto compatiable with the Mopar brand?
Old 03-24-2008, 08:35 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Even the Amsoil Limited Slip Additive is only $7.50 a bottle, where the hell you getting that price? The Dealer?
I usually pay $4.95 to $5.95 a bottle.
Old 03-24-2008, 08:38 PM
NYPANAMA42's Avatar
NYPANAMA42
i was at the dealership today and they indicated that it was $18.00 dollars a bottle.
where did you buy yours Hammer for only $4.95 a bottle?
Old 03-24-2008, 08:43 PM
codiac's Avatar
codiac
codiac is offline
My manual says 4oz....get a new manual. Mine's an 04, I don't imagine it's different. Buy the Mopar junk, or drop the coin for some Royal Purple or Amsoil.
Link to d/l new manual....pg 351 is where I am looking.
http://www.dodge.com/en/owners/manua...00%20%28Gas%29
Old 03-24-2008, 08:50 PM
MikeHTally's Avatar
MikeHTally
75w-90 is the front diff. Unless it's LSD as well (possible but not likely) the additive only needs to go in the rear diff. The stuff I bought at Advance is Trans-X, made by CRC Chemical.
Old 03-24-2008, 08:58 PM
NYPANAMA42's Avatar
NYPANAMA42
Judging from some of the answers given. I guess it would be same to assume that all Diff. Fluids are compatible...Am i right on this?
Old 03-24-2008, 09:07 PM
MikeHTally's Avatar
MikeHTally
Well, according to the shop manual, it must be synthetic, 75w-140 rear, 75w-90 front. LSD additive (four ounces if at stock capacity). When you pop the cover, make sure the c-clips are not floating around. Hopefully, they're in the bottom of the pumpkin, out of the way. If so, MAKE SURE you get all the parts out. If they're still in the clutch packs, you may need to remove them so they don't cost you $$$ later.
Old 03-24-2008, 10:59 PM
mmstar23's Avatar
mmstar23
mmstar23 is offline
so if im gonna open up my differential cover and change the fluid....what fluid do i exactly need? sorry for the newb question but im still learning. and what are the c clips? i know you gotta get and metal shavings or any debris off the magnet at the bottom.
Quick Reply: Limited Slip Differential Fluid?
