Code Po442
Old 02-18-2008, 10:19 AM
MexiRam's Avatar
MexiRam
MexiRam is offline
Default Code Po442
I been clearing this code and it keeps coming back p0442 evap leak monitor medium leak. I have tightened everythin in my intake and tightened my gas cap. Anyone know what else to check.
Old 02-18-2008, 10:39 AM
hemiyellow's Avatar
hemiyellow
hemiyellow is offline
DC Insider
Default RE: Code Po442
EVAP hoses under the truck around the canister area on driver side towards the middle/back of the cab...quite a few rubber hoses there and might have one that has a cut or somethin in it
Old 02-18-2008, 12:39 PM
kenihemi's Avatar
kenihemi
kenihemi is offline
Come on man, you gotta help us out a little bit. What year, what engine, you know that kind of stuff.
Unless its there someplace and I missed it.
Old 02-18-2008, 12:59 PM
4X HEMI's Avatar
4X HEMI
4X HEMI is offline
Well, I would say if the picture is his truck then its a 2002 to 2006 3rd gen.
P0442 is an EVAP code. Evaporative Emmissions. Usually when you get this code its from your gas cap. Either the cap is bad or you didn't turn it enough times after you got gas!
Clear the code, take off your gas cap and put it back on, when it clicks I usually turn mine a few times. See if it comes back on again.
Old 02-18-2008, 10:55 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
It could behoses, Purge solenoid, LDP pump if it has one , NVLD pump if you don't have a LDP pump, or canster.
Quick Reply: Code Po442
