2004 dodge dakota transmission problems.
Old 02-17-2008, 09:54 AM
tspeed109's Avatar
tspeed109
tspeed109 is offline
Default 2004 dodge dakota transmission problems.
I have just changed the transmission filters on my 2004 Dodge Dakota and now it will not move in any gear. The filters that I changed was the regular push in filter and the spin on filter. I have got the error codes Po700 and po841. Can anyone please tell me what this error codes mean?
Any Help with this will be greatly appreciated.
I can not believe it I just changed the filters and put in Dodge atf+4 transmission fluid and now it won't move. I hope that my transmission is not out as I am still paying on the truck. It only has 42,000 miles on it.
Old 02-17-2008, 10:31 AM
dodgerules86's Avatar
dodgerules86
dodgerules86 is offline
Default RE: 2004 dodge dakota transmission problems.
P0700 just means there is a code stored in the transmission control module.
P0841 means the LR Pressure Switch reads open or closed at the wrong time in a given gear.
Are you 100% sure there is nothing blocking the transmission fluid intake.anywhere else? What is the fluid level? (Note, its important to let the transmission run in NEUTRAL for a litle but, since it doesn't pump the fluid in park, checking in NEUTRAL is the correct way)
There is a TSB for this, and a few other CELs. http://www.jameskowalski.com/Dodge/TSB/21-009-05.pdf(applies to vehicles with the 42RLE)
Old 02-17-2008, 07:30 PM
tspeed109's Avatar
tspeed109
Thank you much for your help.
I found out that I did not get the o-ring seal pressed in all the way and it must of been sucking air instead of fluid. The o-ring seal must be pressed in flat, but I did not do that. I had to drop the pan again and recheck everything. another thing I did was soak the spin on filter in atf+4 trans fluid.
Thanks again for your help.
Troy B.
Old 02-18-2008, 10:03 PM
moe7404's Avatar
moe7404
moe7404 is offline
moe in wichita in ks
i was told that the newer mopars trans have a check valve in the lube/coolent line.
this valve can hold trash from a blownup trans and keep the fulid from lubing/ cooling the trans. so just ALWAS clean this check valve, i think its at the radator.
Old 02-19-2008, 12:22 AM
varsis's Avatar
varsis
varsis is offline
ORIGINAL: moe7404
Or remove it... Thats what my mechanic did
Old 02-19-2008, 08:50 PM
moe7404's Avatar
moe7404
moe7404 is offline
moe in wichita ks
WOW! i never thought of just removing it. will that let more fluid flow?
Old 02-20-2008, 02:55 AM
varsis's Avatar
varsis
varsis is offline
I don't think it will let more fluid flow, but if you have a LPD bypass cooler, you can prevent having more mess in your truck, if the check valve cloggs everything ciezes up, if it just has scraps going around well, maybe you might get by, he even showed me it. If the scraps roam they atleast have a chance at getting the magnet...
Also LPD coolers are good at cooling etc.. lots of safety to them. Not even a chance of getting rad fluid in the tranny.
Old 02-21-2008, 09:42 PM
moe7404's Avatar
moe7404
moe7404 is offline
moe in wichita ks
that sounds like a good way to go. my 2001 dak looks like it has a factory aux cooler. i havent checked the numbers to be sure. the service manual i down loaded says that there is a sticker under the pass seat. you have to take the seat out and pull the carpet up to get to it. why would anyone hide it like that?
Old 02-22-2008, 12:52 PM
f0x672's Avatar
f0x672
f0x672 is offline
when my trans went, my transmission guy found that the check valve was almost compeltely closed and was stuck, that why O/D lost adequate fluid flow and cooked itself
Old 03-02-2008, 10:41 PM
tspeed109's Avatar
tspeed109
Hey Moe can you get us the service manual you downloaded?
thanks
Quick Reply: 2004 dodge dakota transmission problems.
