security system reset
Old 02-17-2008, 12:36 AM
jason0409's Avatar
jason0409
jason0409 is offline
Default security system reset
My 2003 dodge1500 truck's security system has locked down my truck.
i was in the grocery store...came out, unlocked my doors with the remote, then was trying to start my truck when the red security light in the instrument panel started flashing and it wouldn't start. I can't get it to start, or reset.
Anybody heard of this or know how to reset it? Is there a reset switch or is it something i have to get done at a dealership. thanks
Old 02-17-2008, 11:21 AM
oefootball_70's Avatar
oefootball_70
oefootball_70 is offline
Default RE: security system reset
Take the black end of the battery off. Thats all I can think of.
Old 02-17-2008, 11:52 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
SeVeReDiStOrTiOn is offline
Try your spare key...otherwise you'll have to bypass it which requires cutting a wire to get the ohm reading and then putting a resistor in-line.
Old 02-19-2008, 11:09 AM
06 Hemi's Avatar
06 Hemi
06 Hemi is offline
Did someone try to start your truck without the key? The newer Dodge's havea Sentry Key, and the way the security systemis set up if someone tries to steal the vehicle and they don't have the key, itdisables the ignition. And I think I read somewhere that after you have to bring it to the dealer to reset the computer, otherwise it will not start, even if you use the correct key.
Quick Reply: security system reset
