Neon SRT-4 Dodge Neon SRT-4 is the pocket rocket that took the import scene and turned it upside down.
wobble in front end
Old 02-11-2008, 04:35 PM
silverbullett's Avatar
silverbullett
silverbullett is offline
Default wobble in front end
I have replaced my front passenger side axle, re-balanced my tires, and tighten down my lugs to spec and there still a wobble comin from the passenger side at low rpms and when at high rpms the wobble goes away. what could it be?
Old 02-28-2008, 11:41 PM
scox1026's Avatar
scox1026
scox1026 is offline
Default RE: wobble in front end
that is a tough one.....
you sure it's coming from the front??
have you checked the tire all around? also could be a broken belt inside the tire causing it to ballon around the sidewall, that would cause a noticable wobble at low speeds....
Quick Reply: wobble in front end
