Antifreeze leaking
Old 02-08-2008, 02:00 PM
Rammin_it's Avatar
Rammin_it
Rammin_it is offline
Default Antifreeze leaking
So yesterday there was smoke coming from my underneath my hood, got my truck home and saw antifreeze leaking on the exhaust manifold but i couldnt see a hose leaking or anything. This morning i walk out and look at it and it looks like the antifreeze is leaking from the bottom of the transmission, has anyone ever seen this kind of problem. I have a 1999 Dodge Ram 2500 cummins. Any help with this would be much appreciated.
Old 02-08-2008, 02:08 PM
Watermelon's Avatar
Watermelon
Watermelon is offline
Default RE: Antifreeze leaking
It sounds like you have the dreaded 53" block, Man I hope not. The 53 is bad about cracking and leaking anti-freeze. It is repairable but costly. I hope this is not your problem. Good Luck and keep us posted,these guys can help you.
Old 02-08-2008, 02:12 PM
energinerbuzzy's Avatar
energinerbuzzy
energinerbuzzy is offline
ORIGINAL: Rammin_it
Sounds like a cracked block to me. I have heard a few guys here lately talking about the 53 blocks? I am guessing it is a block cummins made one model year that has cracking problems?
I'm sure someone will chime in with more info. But it sounds like some of the other post I have seen with cracked blocks.
Go out and look for a crack on the exhaust side of the block or water jacket. Look close cuz it will be hard to see.
Old 02-08-2008, 06:23 PM
roadking096's Avatar
roadking096
roadking096 is offline
I think there is a water to trannyfluid heat exchanger down by the passenger side of the block. Lots of connections there to leak. I would'nt think a cracked block would weep tons of antifreeze.
Old 02-08-2008, 08:40 PM
CowboyBob's Avatar
CowboyBob
CowboyBob is offline
The 53 block cracks below the exhaust manifold. If it is leaking onto the exhaust manifold and burning off, it isn't the typical 53 crack.
Old 02-08-2008, 08:51 PM
CowboyBob's Avatar
CowboyBob
Here's a real good site on the 53 block. Check it out and see if your leak looks like any of the photos.
http://www.stamey.info/Truck/Cummins53BlockFAQ.htm
Old 02-08-2008, 11:26 PM
Rammin_it's Avatar
Rammin_it
Thanks that website is helpful. Still scary i would hate to see the block cracked, since i have babied the crap out of this truck. I will have to look in the morning and see if i cant see better, and look and see if mine is the 53" block. Someone at work told me he had a similar problem and his leak actually was coming from a transmission cooling return line and his was sparying onto his exhaust manifold and running down his tranny, so we will have to see and pray that the block isnt cracked.
Old 02-09-2008, 10:34 AM
CowboyBob's Avatar
CowboyBob
I don't think you have a cracked block. A cracked block isn't going to leak enough coolant to run down to the tranny. Most of it will burn off before hitting the ground, unless you let the crack go for a long time and the opening is huge.
Old 02-13-2008, 11:29 AM
Rammin_it's Avatar
Rammin_it
Took my truck to the dealer on monday so they could work it into the shop, got a phone call this morning and they said it was a freeze plug and that was why it was leaking onto the exhaust manifold. So that was a blessing, and i asked them if they would look and see if the block is cracked and the tech actually called me and was talking to me about everything and he said that he didnt not see the block cracked. I am happy that it was just a freeze plug.
Old 02-13-2008, 12:26 PM
Drew's Avatar
Drew
Drew is offline
have you looked to see what the casting number of you block is???
Quick Reply: Antifreeze leaking
