Notices
Detailing Discuss detailing your ride inside and out here.
Tire foam to clean Engine?
Old 02-05-2008, 01:08 AM
masshole's Avatar
masshole
masshole is offline
Default Tire foam to clean Engine?
I hear that tire foam sprayed on the engine, to clean the grime, is the best thing to use. Anybody done this before? How well did it work for you?
I'm willing to try on a warmer day, it needs a good cleaning. Sorry, if this has been asked before. I did a search and nothing came up.
-thanks.
Old 02-05-2008, 09:15 PM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
Default RE: Tire foam to clean Engine?
regular engine degreaser works far better ... tire shine attracts dust
Old 02-05-2008, 11:00 PM
RAM0447's Avatar
RAM0447
RAM0447 is offline
That is my secret to keeping my engine clean . It'll attract dust, but not right away, it stays clean for quite a while! Just make sure you at least wipe it off after a while....but keeps the hoses perfect(no cracking will ever occur) and the plastics shiny! Just don't spray directly onto your alternator and you're set. But I've been using tire foam on my engine bay for the last 4 years....
Old 02-06-2008, 12:19 PM
bad venge's Avatar
bad venge
Section Moderator
Yes ity SHINES it but it really won't clean/degrease a dirty engine
Old 02-07-2008, 09:07 AM
masshole's Avatar
masshole
masshole is offline
What would you recommend, for an engine cleaner? Should I use an engine cleaner first and then use tire foam, as a shiner?
Thanks.
Old 02-07-2008, 06:31 PM
bad venge's Avatar
bad venge
Section Moderator
If you have access to a steam cleaner that works wonders ....
If not then either Purple power full strength spray on a warm enginns let sit ,scrub any really dirty areas ..Carefully spray it off with water be SURE to keep it from electrical parts/harnesses ...
If not purple power try Engine Brite foaming degreaser ... Same way
Old 02-08-2008, 12:34 PM
masshole's Avatar
masshole
masshole is offline
No, I don't have a steam cleaner..But, I will look for the other stuff!
Thanks..
Old 04-27-2008, 02:04 AM
timbojb's Avatar
timbojb
timbojb is offline
I didn't use the foam but, I cleaned this engine today with a pressure washer, engine degreaser, paint thinner(be very cautious), 400 grit sandpaper, mothers mag aluminum polish, armorall tire shine, and some microfiber rags...
[IMG]local://upfiles/88359/31C1C1BD44C24059AE87A85F33A726AD.jpg[/IMG]
edit... btw it hadn't been cleaned in 100k miles of me owning the truck... it looked like it was dipped in grease and then rolled in dirt.
Old 05-14-2008, 10:57 PM
RealMcCoy30's Avatar
RealMcCoy30
RealMcCoy30 is offline
looks really nice! I need to clean mine up some too. Glad I found this thread
Old 05-21-2008, 12:57 AM
nbstriker10's Avatar
nbstriker10
nbstriker10 is offline
i usually use a little WD-40 and a rag... shines everything up like new...
Quick Reply: Tire foam to clean Engine?
