P2305, Coil, Fuse#21
Old 02-04-2008, 08:42 PM
porch's Avatar
porch
porch is offline
Default P2305, Coil, Fuse#21
I have a 2004 Dodge Neon SXT and I am having major problems with it. It all started one morning when my car would not start. I ended up flooding my spark plugs but I did get new once to replace them with. One night it did start but was not running right. We made it about a mile down the road and she just cut off. When we would turn the key the lights, radio, power windows everything would come on and work.But she just wouldnt make a sound when you went to crank her.
But long story short here are my problems:
1.) I am getting P2305.
2.) I have gone threw 3 new coil packs. Once we puta new pack on and go to crank the car, You hear a pop and the coil cracks between 2 and 3.
3.) Fuse #21 keeps blowing. Every time you go to crank it you hear the coil crack then the fuse goes.
I am all out of ideas! It has got to be something so simple but I just dont know what would make my fuse blow and my coil pack crack like this.
Old 02-05-2008, 12:48 AM
Kalevra's Avatar
Kalevra
Kalevra is offline
Default RE: P2305, Coil, Fuse#21
still have a warrenty on it?
Old 02-05-2008, 05:12 PM
2003SXTneon's Avatar
2003SXTneon
2003SXTneon is offline
i was getting p0300 and i took it to the dealer and it was my coil. it was covered. anything thats not considered "wearable" is covered.
Old 02-13-2008, 08:05 AM
porch's Avatar
porch
porch is offline
I am getting fire to the coil but it's not leaving would that be the computer or does anyone knows what tells the coil to fire and to leave the coil. I know that the fire is going to the coil because that why three of them has cracked . Thanks again
Old 02-13-2008, 08:06 AM
porch's Avatar
porch
porch is offline
Old 03-02-2008, 08:20 PM
cookendorfernick's Avatar
cookendorfernick
cookendorfernick is offline
I'm having a very very similar problem. Does anyone have an answer to this?
Old 03-02-2008, 10:44 PM
HarleyRider68's Avatar
HarleyRider68
HarleyRider68 is offline
All the PCM does is ground the coils to complete the circuit and charge the coil. Check the ground on the #3 pinout on the PCM.If that wiring checks out, I'd look on the spark plug side.
Old 03-03-2008, 03:55 PM
cookendorfernick
Hello. I am cross-referencing my thread with this one, so if anyone can provide help, I have posted my full problem here. But my issue is related to this thread as well. It appears to be the same/similar issue. Thanks in advance!!!!
Old 04-08-2008, 07:52 AM
cookendorfernick
Took it to the shop. Confirmed it is the PCM. I don't have the money to fix it. Just wanted to let everyone know what the problem was just in case anyone comes across this in the future. Good luck!
Quick Reply: P2305, Coil, Fuse#21
