Old 08-07-2015, 12:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine
Print Wikipost
Kegger Intake Mod DIY
Old 02-04-2008, 05:38 PM
Silver_Dodge's Avatar
Silver_Dodge
Silver_Dodge is offline
This is a do-it-yourself on modding your intake manifold on a 5.2/5.9 Magnum V8. This is done to allow it to breath a little better, escpecially at mid to upper RPM range. First, some terms that will be used. The stock intake manifold sits directly beneath the air cleaner assembly and throttlebody. It is often referred to as a kegger because it looks like a small beer keg cut in half the long way. The kegger is a plenum design intake. This basically means that it holds a large volume of air inside. This air comes into the intake through the throttlebody, then into runners that then feed air into the cylinders on each intake stroke. On the bottom of the kegger is steel pan called the belly pan. A common problem with the kegger/belly pan design is that the gasket between the kegger and the belly pan can leak. This causes a vacuum leak and oil can enter into the intake plenum space. You will often hear people call this the plenum leak or plenum repair. In the DIY section, #16 is the thread on repairing your plenum pan leak.
https://dodgeforum.com/m_904616/tm.htm
The purpose of this DIY is to address only the modding of the intake, not repairing the plenum gasket.
Here is what a kegger looks like with some labels of the main components of the intake.
If you've decided to mod your kegger, you have two choices. You can either use the intake that is already on your truck, or you can buy a spare one and mod it on the side at your leisure. If you use the one that is on your truck, a good time to do this mod is if you are repairing your plenum gasket. If you buy a spare one, make sure you buy the correct one for your truck. There are two things to look for before buying a used kegger. First, if your truck has EGR ('94-'95, some '96, and some '97), make sure you get an intake that also has the EGR port. If your truck is '98 or newer without EGR, any '98 or newer intake should work, and one without a center divider would be the preferred intake to buy (more on that later). Second, see how many coolant temps sensors are on your truck. Some have one (some '97 and later), and some have two (some '97 and earlier). If your truck uses only one, you can use an intake that was made for either one or two (just plug the extra port if it has two ports). If your truck uses two, it is best to look for an intake that has two ports already. You can try taking one that only has one port, and drill and tap your own port, but this would not be the desirable method. Just keep looking for one with two ports already drilled out by the factory for you.
Using a spare intake has some advantages over using the one on your truck. One is that you can be working on it while still driving your truck, and at your own pace. Then it is ready to install when you want. Secondly, once you install the spare intake on your truck, you have the original one from your truck to either mod again, sell, or just keep as a backup. Thirdly, once you are done modding your intake, you can install the belly pan. This lets you have plenty of time to let the gasket sealer used on the belly pan gasket (ultra copper is what I used) cure before installing the intake in your truck.
Ok, on with the mod. My truck is a '99 with a 318. The stock intake is non-EGR. I bought an intake from a '97 that was also non-EGR to use as a spare intake. My truck only uses one coolant temp sensor port, but this intake has two. I'll just plug the second port later. The intake cost me about $25 shipped from a guy selling it on the forum. The steps below outline how I modded the intake. I will mention the tools I used, but it is really up to you and the tools you already have or are willing to buy. From start to finish, these steps took about 7 hours of total labor. I did it across the course of three evening.
1) The first thing I did was to remove all sensors and coolant lines from the spare intake. I also removed the belly pan that was still on it.
2) Next, I took the intake to a machine shop to have them check all the surfaces for trueness, and to machine as necessary. You don't want to waste time modding the kegger if it is not a good straight peice to begin with. A bad intake will result in leaks after it is installed. I also had them clean it up in a dunk tank so that it was free of oil and coolant debris. This cost $25 to have done.
3) Now it was time to start cutting it. I highly recommend that you do this on a wood work surface of some other soft surface. Since the intake is aluminum, it is easy to damage the surfaces as you are working on it on a work bench. A wood surface will not hurt the aluminum.
The first thing I did was to mark and cut the runners. On a 5.2, 1"-1.25" off the runner is considered by many to be appropriate. On a 5.9, you can cut the runner all the way down. Here is the mark I used as a guide. Use a sharpy and a straight edge to make your marks. Notice that I decided to make my cut at an angle to the existing opening edge of the runner. This opens up the runner more to the center of the plenum space, but keeps the backwall of the runner almost at its stock length. Another possible way is to make your cut parallel to the existing edge of the runner. Doing it this way would keep the opening direction of the runners the same as they are from the factory. It is up to you how you want to make the cut. No one has done enough testing of this mod to now yet which way works the best.
4) I then used a sawzall to cut the runners. I recommend using eye protection and even ear protection as you cut. It is very loud, and small slivers of aluminum can fly up. Cut slowly, so you do not overheat the blade. Use a blade rated for metal 3/16"-1/4". Be very aware of your blade as you cut. It is easy to cut up the belly pan mounting surface if you don't watch were your blade is. This could cause oil leaks into the plenum later. Also be aware of the clearance around the tip of your blade. As you can see, the cut is not quite in line with my mark. This is because the angle of my line was too sharp for the sawzall. I would have cut into the belly pan mounting surface if I had stayed on my line. You can leave it like this, or get back on your line using other smaller cutting tool (Rotozip, Dremel, or even a hand file for example). As you near the end of your cut, slow down so that you don't bust through the cut and hit your blade on something you didn't intend to.
Here is the finished cut:
Repeat the same cut on the other runner pairs.
5) Next, if the intake you are modding has a center divider, cut the ends as show below. Be careful as you get near the bottom because it is easy to hit the tip of the blade as it reciprocates. You may have to flip the intake over and make the same cut, but from the other side to get a deeper cut. Repeat on the other end of the center divider.
6) Next, I started smoothing up the runner ends. You can do this now, or after you remove the center divider. I wanted a break from the sawzall, so I started on them here. The idea is to make the cut edges smooth so air can flow into the runners without generating turbulance. I used the drill tip you see in the picture. It did an amazing job of removing material and was easy to control. I'm not sure what it is called as I just had it laying around at home, but I saw ones just like it at Napa and at home improvement stores. I used the trigger lock on the drill so that it didn't require my finger to keep it running. This made it easier on the hands and easier to control the drill to slowly cut the material until the surfaces were nice and smooth. You can also use a metal hand file to get any other areas that might be too hard to reach with the drill.
Repeat on all the runners until they are all smooth both on the outside and inside edges.
7) If your intake has the center divider, it is time to remove it. Chrysler engineers figured out after a few years that the removal of the center divider promoted better air flow. Most '99-'01 intakes do not have the center divider. Since the intake I am modding is a '97, it has is. First, I tried to use a dremel to cut along the bottom. Even though this was easy to do, the blades broke very easily and did not make much progress.
Notice you also need a very small diameter cutting wheel to fit in the confined space, so the EZ-Lock blades can not be used here becasue they are too big around.
At this point, I decided to use the sawzall to remove as much of the center divider as possible. I figure this would make removing smaller pieces of it with the dremel easier then trying to cut the whole length of the divider with the dremel. I used a combination of angled cuts and straight cuts as you see here:
Then, I used a hammer to remove smaller pieces that were between the cuts. This worked well and in no time I had the vast majority of the center divider removed. Make sure the peices you are trying break with the hammer are not too wide (the one pictured here was almost too wide). This might require additional cuts with the sawzall, but better that then breaking the intake by trying to snap off too big of a piece.
8) Next, I used a dremel with 1 1/2" EZ Lock cutting blades (an EZ Lock fastner is required to use these blades, but it is worth the expense because it is so much faster to change the blades). These blades do a good job, but they break easy, so go slowly, and don't apply too much pressure. You will want to have 10-20 blades on hand.
Here is the intake at this point
Remembering how easy the center plate broke with the hammer, I decided to use a pair of vice grips to grab and break any larger areas that remained (were I couldn't reach with the hammer). This worked very well.
Once I got as much as I could, I went back to the cutting bit on the drill and smoothed up all the cut edge of what was once the center divider. I also did some more smoothing on the runner edges because I could reach them better now that the center divider was gone. Then I used a course brass wheel to remove any burrs and other material that could later become dislodged and get sucked into a cylinder. Pass your hand around the entire inside of the intake and make sure it is as smooth as possible everywhere.
9) Next, clean up the injector bosses. You want to remove a little material around the outward facing edge of each hole. This gives the injector stream a little better ability to make a good spray into the combusiton chamber. Without this, part of the spray can hit the edge of the injector boss hole, and then drip down into the cylinder. Be very careful not to remove too much. If you cut upwards into the injector hole too much, you can cause the injector o-ring to not seal good. If you cut to much away from the outside edge of the intake, you will be cutting into the intake manifold gasket surface. I used this rounded grinding tip attached to a dremel as you see here. It was the perfect size and shape for the cut I was trying to make.
From the other side, I used this small brass wheel on a dremel to clean out any dirt and grime that is in the injector holes. This gives a nice clean surface for the o-rings to seal against when you install the intake.
10) Next, I used a brass wheel attached to a drill to clean up all the mounting surfaces (thermostat, belly pan, throttle body, etc...). Then I used the brass wheel on the entire outside body of the intake. This gave it a nice shine and removed any dirt and grime that had built up on it over the years. If your so inclined, you could also paint the outside of the intake with high temp paint.
11) Look into the runners from both ends with a flashlight. If there is carbon buildup or other debris, it is a good idea to clean it out. I used the Mopar Combustion Chamber Cleaner sprayed into all the runners. I let it stand in there for a couple of hours. Dump the cleaner out, and spray a powerful stream of water into each runner to dislodge any other debris that may have built up in there over the years. Repeat as necessary. When you are satisifed that they are clean, it is time to give your intake a bath.
12) Fill a large plastic tub or even a bath tub with water. Dunk the intake into the water repeatedly. Use a soft brush or a fine brass brush to gently scrub the entire intake, inside and out. This will remove all the small slivers of aluminum that were created as you were cutting and filing on it. I then removed it from the tub and used a hand held water hose to wash it out thouroughly, making sure to get inside each runner, in the injector holes, and in the coolant passages. You want to get it as clean as possible. Let it air dry and check it for cleanliness. Repeat as necessary.
13) I then installed all new hardware. This included a heater hose inlet nipple, thermostat housing, IAT sensor, waterpump bypass hose nipple, and coolant temp sensor. Some trucks use two coolant temp sensors as mentioned earlier. Others use only one. If your intake had two ports, but your truck only uses one, just buy a small plug to plug the hole for the other coolant temp sensor hole. Use high temp thread sealant on anything that you are screwing in to the intake. Also, you may need to block off one or more of the vacuum ports. Notice in the pictures below that I had to plug one on the driver side of the intake so that it matched the number of vacuum ports on my '99 intake. These small rubber caps can be purchased at most auto parts stores.
Here is how the intake looked at this point.
14) Lastly, install the new belly pan and gasket. I highly recommend using the aluminum plenum pan kit that can be purchased from Hughes or APS Precision. Follow the instructions that come with the kit to install the new belly pan. This aluminum belly pan *******ly eliminates any future leaks.
For more discussion of this topic, see this thread too. It is the first thread I started on this topic, and it has some good discussion and additional pictures.
https://dodgeforum.com/m_968020/tm.htm
After installing my modded kegger, I can tell a nice gain in power in the middle to upper rpm range. It pulls much harder all the way through the shift points. I also need less throttle to accelerate up to highway speeds. I'll be curious to see if I will have any mpg gains from this mod. I'm still testing it out and will post more comments as I drive it more and more.
I'll open this thread up to your questions now, and will place a link to it in the DIY that is at the top of the 2nd Gen forum. It will be DIY #27.
Old 02-04-2008, 08:54 PM
IndyRamMan's Avatar
IndyRamMan
IndyRamMan is offline
Default RE: Kegger Intake Mod DIY
I dont believe you cut the runners right. From what I understand, its supposed to be flat, not angular. But anything is better than nothing. Just wont be as good.
Old 02-04-2008, 08:55 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
Nice job Silver! great DIY, did you reset the PCM? Notice any low end loss of torque/acceleration? Also just a thought? could this buck into the order of DIY to reside right next to the plenum fix DIY? Makes more sense to me to group them by relation to each other than by randomly completed DIY's. Just My Opinion.
Old 02-04-2008, 09:16 PM
Silver_Dodge
ORIGINAL: IndyRamMan
Yes, that is another possible way of doing the cuts, but I don't really think anyone knows what the "right" way to do this is. Unless you cut several of them and do dyno testing to compare which is better, you'll never know if any one way was better then an other. How can you say it won't be as good, have you tried both cuts and compared the two on a dyno to see which was better?
ORIGINAL: aim4squirrels
yes, I reset the PCM. I've only driven about 20 miles so far. I've noticed no low end loss at all. It is actually better, but that is probably mostly due to fixing my plenum leak. Actually, after thinking about it, I think it is best if we just leave the DIY's the way they are. I don't want to move them around because they could be referenced in other threads. Moving them would change that.
Old 02-04-2008, 10:49 PM
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
Awesome writeup! I cut mine in a similar way with the cut off wheel... my mods worked awesome up past 5k on the 5.9. How do you like it now now that it's done?
Old 02-04-2008, 11:56 PM
Silver_Dodge
Still need to put a lot more miles on it before I say for sure how Ilike it, but so far i'm happy. I'll keep you all posted as I continue to test it.
Old 02-05-2008, 12:35 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: Silver_Dodge
not only is it another possible way to do it, its the proper way. hope that tech certification means something in the end.
Old 02-05-2008, 12:42 AM
Cereal Killer's Avatar
Cereal Killer
Cereal Killer is offline
It means he can adjust his valves without setting his truck on fire
Old 02-05-2008, 12:50 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: Cereal Killer
****...guess i should get me one of them patches before i try again!
Old 02-05-2008, 01:06 AM
padodgeram's Avatar
padodgeram
padodgeram is offline
leave it to silver with thedetailed write up. thats why he has the patch...hell even i gotta ask him questions on these motors and i work in the field..
Quick Reply: Kegger Intake Mod DIY
