transmission problems, overfull fluid?
Old 02-03-2008, 04:18 PM
soccerjon1013's Avatar
soccerjon1013
soccerjon1013 is offline
Default transmission problems, overfull fluid?
hello, i had my transmission fluid changed on thursday in North Ohio, I drove down towards North Carolina, but broke down in West Virginia, about 350 miles from where i had my truck serviced. the vehicle ran fine, then all of the sudden, i was driving up a hill, and it felt like it went into neutral and would no longer change gears. i let the vehicle sit for about an hr and tried again, but had no luck, it would shift into first and reverse, but would return to neutral after about 20 yards. I checked the trans fluid, and it was about 2 qts over filled. Is there anyway that this could have caused my transmission to act this way, is there an easy fix or is this a serious problem, or would there be something else that may have happened to cause this problem
Old 02-03-2008, 04:26 PM
padodgeram's Avatar
padodgeram
padodgeram is offline
Default RE: transmission problems, overfull fluid?
being overfilled is just as bad as being underfilled , damage may happen .. drain the 2 extra quarts ASAP.. did you check the fluid while in N ?? engine running ??? i would call the shop and say something if thats the case.. and what type of fluid did they put in ??
Old 02-03-2008, 04:41 PM
nolazach's Avatar
nolazach
nolazach is offline
If they didn't use the chrysler fluid that could cause problems. The ATF+4
Old 02-03-2008, 04:57 PM
HellaciousHemi's Avatar
HellaciousHemi
HellaciousHemi is offline
Yes, overfilling will cause erration in the fluid and damage the transmission. Look on your dipstick to see if that says the particular fluid it needs. My 1998 1500 4x4 takes Dexron/Mercon 3 so there is actually more than just the ATF+3 or 4 for what can berequired.But I just put Amsoil in it.
Old 02-03-2008, 05:24 PM
Houston4x4's Avatar
Houston4x4
Houston4x4 is offline
Overfilling should only be done after the trans is out. It's a good trick to get the truck off the road.
Old 02-03-2008, 06:14 PM
motorbrreath's Avatar
motorbrreath
motorbrreath is offline
yeah over filling can do that, buddy of mine overfilled mine when i first got it. caused problems until it was drained.
Old 02-03-2008, 06:30 PM
soccerjon1013
not sure what kind of fluid they used, so yours wouldn't shift into gear at all? but was working fine as soon as it was all drained and filled to the proper level?
Old 02-03-2008, 06:33 PM
motorbrreath
ORIGINAL: soccerjon1013
i had it serviced in the mountains, so it was only about an hour drive on the highway, when i got off the highway the truck didnt wanna move at all. the fluid had expanded and made it not go into gear. i would drain all that out, put some new fluid in it (i think its 5 quarts) atf+4 and see if that helps. it might have burnt your clutches/bands up goin the distance you did.
but look at it this way, if the shop messed ur tranny up, they should take care of it.
Old 02-03-2008, 10:42 PM
highlander73's Avatar
highlander73
highlander73 is offline
ORIGINAL: HellaciousHemi
A Ram uses Dexron/Mercon 3? Never heard of that one.
Old 02-03-2008, 11:19 PM
motorbrreath
ORIGINAL: highlander73
no ram uses dexron... they all use atf+4
Quick Reply: transmission problems, overfull fluid?
