2000 Dodge Caravan Sport Transmission?
Old 01-29-2008, 10:56 AM
sl1r0n's Avatar
sl1r0n
sl1r0n is offline
Default 2000 Dodge Caravan Sport Transmission?
I own a 2000 Dodge Caravan Sport 3.3L. This winter it started to have difficulty shifting from reverse to drive, the rpms go but the van dosnt. Also when stopping then going again, theengine will rev the van will not move then something catches and it will go. Transmission maybe? Ive read alot of "war stories" about the caravan tranny. Any ideas or suggestions would be great!
Old 01-29-2008, 07:14 PM
holtzer1's Avatar
holtzer1
holtzer1 is offline
Default RE: 2000 Dodge Caravan Sport Transmission?
yep, transmission is slipping
what does the fluid look like? full? color? metal flakes in it?
Old 01-29-2008, 11:00 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Does the trans slip in reverse too? I would have the tcm ck'ed for codes. You could be loosing pump pressure,burnt clutches,or the low/reverse actulator. The snap ring breaks sometimes causing to loose reverse and 1st gear.
Old 01-31-2008, 08:25 AM
sl1r0n's Avatar
sl1r0n
sl1r0n is offline
Thanks guys ill check it out and let you know what i see.
Quick Reply: 2000 Dodge Caravan Sport Transmission?
