Early or Late '04?
Old 01-23-2008, 08:54 PM
RAMbunkshus's Avatar
RAMbunkshus
RAMbunkshus is offline
Default Early or Late '04?
I've got an '04 CTD, but am not sure if it's an early or late (after Cummins upgraded the HP and torque ratings) model. Is there a list of VIN's that will identify my truck as an early or late '04?
Old 01-23-2008, 09:17 PM
Parts/Service's Avatar
Parts/Service
Parts/Service is offline
Default RE: Early or Late '04?
Give me the last 8 digits of your VIN and I can tell you the exact date your truck was made....
Old 01-24-2008, 09:48 AM
RAMbunkshus
ok, it's 4G153213 Thanks, I apprieciate your offerto help.
John
Old 01-24-2008, 04:25 PM
Drew's Avatar
Drew
Drew is offline
you can also look on the valve cover. . .if the HP rateing is 325, then you have an 04.5, if it is a 305hp model then you have an early 04. also the build date of the truck will also tell you, after Jan 04 then you have the 600 engine, before that would be the tripple nickel.
Old 01-24-2008, 08:03 PM
Parts/Service
Your truck was built November 11, 2003.
Old 01-24-2008, 08:51 PM
bekim's Avatar
bekim
bekim is offline
That makes your an '04. The 04.5's have a build date on or after 1/1/2004
Mike
Old 01-25-2008, 01:56 PM
bigmike's Avatar
bigmike
bigmike is offline
I believe the early 04's also had a 3.5 inch exhaust, as apposed to the 4" for the 04.5's.
Old 01-25-2008, 02:47 PM
aka_chewy's Avatar
aka_chewy
aka_chewy is offline
That is correct. I have an early 04 and it's 3.5" from the turbo to the muffler, then 4" from the muffler out.
Quick Reply: Early or Late '04?
