2002 Durango gear shift
Old 01-21-2008, 11:52 AM
blucrubub's Avatar
blucrubub
blucrubub is offline
Default 2002 Durango gear shift
I have a 2002 Durango. Sometimes the gear shifter gets stuck in park. Anybody have any ideas on what is causing this to happen? Thanks
Old 01-21-2008, 12:02 PM
deerang's Avatar
deerang
deerang is offline
Default RE: 2002 Durango gear shift
the gear safety switch gets stuck... over the years the grease wears down and the little latch sticks and won't allow you to take it out of park...
I'll try to search for the old thread for you. But basically what you do is take the pastic cover off from around the gear selector, and grease the latch, you'll be able to figure out what it is, its the thing that looks like it inhibits the movement of the gear selector...
Old 01-21-2008, 12:05 PM
Moneyqueen's Avatar
Moneyqueen
Moneyqueen is offline
My 2002 does that sometimes. I try pressing on the brake harder and moving the steering wheel. Luckily it has only happend 2 times and came out of it pretty quickly. ButI've only had my truck a couple of months too.
Old 01-21-2008, 12:12 PM
blucrubub's Avatar
blucrubub
Cool, thanks im gonna check into that here in a little bit. Ill let ya know what happens.
Old 01-21-2008, 01:17 PM
deerang's Avatar
deerang
deerang is offline
searching park in this forum i came up with a few old threads
https://dodgeforum.com/m_703960/tm.htm
https://dodgeforum.com/m_681621/tm.htm
my internet connection is too slow to load these right now, so take a look and see if it helps
Old 01-21-2008, 02:52 PM
blucrubub's Avatar
blucrubub
Thanks for all the help buddy! Really appreciate it, well keep this site in my favorites for the future! Thanks again for your help everyone.
Old 12-02-2008, 04:35 PM
cyclopsblown34's Avatar
cyclopsblown34
cyclopsblown34 is offline
Links is broke but your advice should help me a bunch. It just did this yesterday and scared the stuffin out of me, I was assuming it was a safety interlock like several other vehicles I've worked on. I'll work on the wife's 2002 Durango this weekend. 140000 miles and I just enjoy the heck out of it. It's an SLT plus with a 360 and 4wd.
Thanks a bunch,
Chip.
Old 12-20-2009, 05:05 PM
tonymcclanahan's Avatar
tonymcclanahan
tonymcclanahan is offline
Default Stuck Gear Shift 2002 Durango
I simply sprayed some WD40 above the brake peddle area along the steering column, and down the gear shift around the rubber casing. This worked well the two times the shifter wouldn't get out of park.
Quick Reply: 2002 Durango gear shift
