13 No change in MAP from start to run (help truck wont start)
RE: 13 No change in MAP from start to run (help truck wont start)
Could be the sensor is dead. You could have a bad vacuum leak.You couldhadbad wires.You could not have enough fuel or spark. You could have bad timing. There is lots of posibiltys. You need to give more info. Does the starter turn? Does it try to start? Did you do any work before it did this?
