2nd Gen Durango 2004 - 2009
2004 dodge durango 4.7 Ticking Noise when started up
Old 01-16-2008, 10:36 AM
tjbmmb's Avatar
tjbmmb
tjbmmb is offline
Default 2004 dodge durango 4.7 Ticking Noise when started up
I bought the durango about 3 months ago it has 86000 miles on it. The noise just started out of nowere the other day. It makes a ticking noise right when i start it up. the noise will go away after about 5 minutes. The noise willl speed up if i hit the pedel if that helps any.
Thanks
Old 01-16-2008, 12:02 PM
United1's Avatar
United1
United1 is offline
Default RE: 2004 dodge durango 4.7 Ticking Noise when started up
Broken exhaust manifold studs are a fairly common thing on the 4.7's. When the manifold is cold, there isa gap between the manifold and head, causing the leak. Once the manifold heats up, it expands, and the leak closes. That is why it is typically heard only the first few minutes. Now, your ticking could be a few other things (I am assuming that oil level is OK) but I would check the studs. Do a search for it, someone posted some good pics in the past.
Old 01-16-2008, 12:07 PM
Blaisenj1's Avatar
Blaisenj1
Blaisenj1 is offline
I am pretty sure it is probably your exahust manifold. I have had this problem forever. I took it to the dealer in 05 and they "fixed it". Yea right!!! what they actually did was drilled out the hole too far and it worked for a while but it starrted again. You can buy the gasket for about 13.00 at Adsvance auto or Auto Zone. You can fix it yourself it you are mechanically inclined. My husband fixed mine in about 3 or4 hours. It wasn't too bad to get to. I hope this helps.
Old 01-16-2008, 02:02 PM
n8ech's Avatar
n8ech
n8ech is offline
+3 on a manifold issue. These are classic symptoms of loose or broken exhaust manifold bolts.
I have also heard of some folks having intake maifold bolts breaking as well.
Don
Old 01-17-2008, 09:10 AM
tjbmmb's Avatar
tjbmmb
tjbmmb is offline
thanks for the quick response, Yeal oil level is ok and I will look for the bolts, is there a way to search the forums?
Old 01-17-2008, 09:23 AM
tjbmmb's Avatar
tjbmmb
tjbmmb is offline
Ahh, i found the search at the bottom, I have another question tho, when i get near 100k miles are there any real imporant preventive maint i should do.
Old 01-17-2008, 11:41 AM
n8ech's Avatar
n8ech
n8ech is offline
TJB:
At 100k, your cooling system should be flushed and refilled w/ new anti-freeze. Also, if the tranny, T case, and front rear diffs have not been serviced, this is the time to do it.
FYI, the factory sparks plugs are only rated for 30k, so I would pull a plug or two and give em a look. If they are worn much beyond spec, replace em.
Don
Old 03-10-2009, 02:44 AM
Chazb06's Avatar
Chazb06
Chazb06 is offline
I'm having the same issue with my 4.7 D, sound like a diesel.
Old 03-10-2009, 10:26 PM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
Most 2004+ 4.7s don't get the manifold bolt broken issue. Nearly none of the 2007+ 4.7s never do (redesigned)
4.7s do slap and tick a lot at start up. Run a good oil and see what happens right after the oil change. Also, run a quart of MMO or the like for an hour before the fluid swap.
IndyDurango
Old 03-11-2009, 08:21 AM
Chazb06's Avatar
Chazb06
Chazb06 is offline
When I first bought the D I may have been OK with a engine tick but I think their is something going on with possible the exhaust. It sounds to much like a hole in the muffler at start up.This wasn't the case 2 years ago it was smooth and quit. I plan to have mind check out. I will report what I finding.
Quick Reply: 2004 dodge durango 4.7 Ticking Noise when started up
