HELP !!! - I can't find the oil pressure sending unit
Old 01-13-2008, 03:16 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
Default HELP !!! - I can't find the oil pressure sending unit
I'm out back right now trying to find it. I've got manuals open, and I'm looking for the ECM. Apparently it's somewhere near there. I have no clue.
I'm going out back right now to take pics. BRB.
Old 01-13-2008, 03:27 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
Default RE: HELP !!! - I can't find the oil pressure sending unit
OK, hehe we go ...
Wouls someone kindly circle the sensor or at least the general area where I should be looking?
Thanks !!
Old 01-13-2008, 03:34 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Kev_n_AZ is offline
my book shows it behind the power steering pump if that helps.
(although my book only shows to 1996 ctds, but they could not have changed much)
Old 01-13-2008, 03:38 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
Yeah, my first book showed the same, however my supplement book showed it near the ECM. Here ya go. This is what parts/service told me when my light came on.
Sounds like your oil pressure sensor is dying. Part # 5012991AD. Check the connector to make sure its clean and tight. Its beside the engine control module mounted on the drivers side of the engine block. Look for a silver box about 8 inches by 12 inches square. That is the ECM, sensor is next to that......
A silver box 8X 12 you would think would be hard to miss, but I can't find it
Old 01-13-2008, 03:43 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
I "think" I found the ECM. I "think" it's bolted right onto the block behind the stock fuel filter housing. Does that sound right?
Old 01-13-2008, 03:44 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Kev_n_AZ is offline
according to the diagram from Dave, the pcm bolts to the block.
have ya rolled under the engine with a flood light?
Old 01-13-2008, 03:48 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
Yeah Kev, I took one out and I think I see the sensor now. I'm putting the cover back onto the throttle cables now. I took it off because I thought it might be up there since there is a bunch of wires up there. Of course in the process, I broke a plastic screw. [:@]
Old 01-13-2008, 03:52 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Kev_n_AZ is offline
silicone will replace that screw
Old 01-13-2008, 04:10 PM
woligator's Avatar
woligator
woligator is offline
its on the side of the block u dont see it on ur pics mayfair
Old 01-13-2008, 04:16 PM
NickBeek's Avatar
NickBeek
NickBeek is offline
If your engine and ecm are similar to mine, that drawing shows the sensor BELOW the ECM. Use the plugs going into the ecm as a land mark.
Quick Reply: HELP !!! - I can't find the oil pressure sending unit
