Fault Code P2609 & P2509
Old 01-08-2008, 09:54 PM
gibkidd's Avatar
gibkidd
gibkidd is offline
Default Fault Code P2609 & P2509
I've got a 2007 2500 with a 5.9 CTD. A little of a month ago after the grid heater cycled while starting on a cold night, the CEL came on. Code P2609 (intake heater grid abnormal voltage drop). It started and ran fine afterward so I didn't think too much about it and after a couplefailed attempts to reset the code by leavingthe battery cables off for about 30+ min, I decided to live with it until it was convenient to take it in.
About 2 weeks ago while starting it in about 20 degree weather, the light shut itself off and stayed off until this morning when starting it in about 50 degrees temps --for some reason the intake heater light came on even though it was really warm--the CEL came back on and is now showing code P2609 again along with P2509 (ECM/PCM Power Input Signal Intermittent).
Anyone have anyexperience with this? I looked up theP2509on this forum but it looks like a while ago when someone had an issuethe dealearship was stumped. Should I be worried? Am I ok to drive and start in cold weather?
Thanks!!!
Old 01-08-2008, 10:00 PM
amock's Avatar
amock
amock is offline
Default RE: Fault Code P2609 & P2509
Dont know what to tell you about gettin it fixed. But my 03 cummins, the wait to start light comes on no matter what the temp is outside. It just goes off faster than when its colder.
Old 01-08-2008, 10:32 PM
Parts/Service's Avatar
Parts/Service
Parts/Service is offline
Both of these could be caused by weak batteries or loose cable connections. I would check all battery cables. Could also be caused if + cable is shorted to ground....You should take it in if its under warranty, there is a diagnostic flow chart to help diagnosis this.... Hope this helps...
Old 01-08-2008, 11:16 PM
Drew's Avatar
Drew
Drew is offline
if I remmeber from a little digging I did find that te 2509 code is set when one or both batteries are weak or dead. this would be the first place I would look.
Old 01-09-2008, 12:03 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
P2509 has a TSB 18-001-07 which is a flash and P2609 you may have an open battery wire or short, P2609 no voltage drop seen from intake air heaters.
Old 01-10-2008, 10:19 AM
2007 SLT Hemi Power's Avatar
2007 SLT Hemi Power
2007 SLT Hemi Power is offline
Code 2609:
Took the truck in to the dealer and they found bad ground at intake heater, so they replaced the intake heater gaskets, engine light is off now..and added the F19 roll over hose recall.
Old 01-29-2009, 09:32 PM
www's Avatar
www
www is offline
Default p2509
i have a 07 2500 diesel 16,000 miles. about 3 months ago started in morning ran for five to ten minutes shut off check engine light on. truck started right back up and ran fine temp was about 30 outside. now this happens daily and even shuts off while i'm driving always starts right back up.only happens with cold engine. if you make it thru 15-20 minutes truck works great! dealer says code is p2509 they put new fan clutch on still doe's it ! its back at dealer now. help !!!!!!!!!!!!
Old 01-30-2009, 09:43 PM
cumminnotstrokin2's Avatar
cumminnotstrokin2
cumminnotstrokin2 is offline
I believe that was my truck, the dealer had the truck for a month they ended up replacing the ECM after 2 new batteries twice, new wiring harness, grid heater, battery temp sensors, and some other crap. The truck has been great since.
Old 04-16-2012, 03:08 PM
jackola's Avatar
jackola
jackola is offline
Smile
There were a few guys trying to figure out how to get the instruments to go thru their light check cycle.
Most of you know, but if you dont, all you do is push the odometer reset in and turn the key on then let off the reset.. Dont start the truck.
Works every time.
Old 04-16-2012, 03:11 PM
jackola's Avatar
jackola
jackola is offline
I had dead batteries this morning and got a p2509 code. I jumped the truck and let it idle for a few minutes and reset the code. The truck starts and the light is out.
I was lucky, so far......no new batteries.
Quick Reply: Fault Code P2609 & P2509
