Last edit by: IB Advertising
Browse all: 4WD
- Dodge Ram 2nd Gen Drive Shaft Review and How to Install Drive Shaft
Review of top products and step by step instructions.
Browse all: 4WD
where is crankshaft position sensor ?
i have haynes book on my car and there does seem to be a sensor where it states but looks nothing like the part i was given from parts store ... so i want to be sure im looking at right part ....this sensor is in back of block nearest the wall above a boot to steering ......
i took this sensor out and oil came out hole ..im assuming thats normal since the crank section should be lubed lol ...but it seems to have a flat surface which goes inside the engine compartment and a hole in center ..so does the sensor have like a nipple /plunger looking part that is supposed to be in center of this sensor?
thats the only sensor in back of engine and Haynes has no other sensor listings anyplace else...
sorry 2004 dodge stratus 2.4 DoHC and VIN marking X
RE: where is crankshaft position sensor ?
i really am glad you gave me the image as i was thinking i was stupid but after seeing the image ...now im positive ...its not there ...would it make a difference if the autozone guys after looking up parts said my car was late model 03 sold in 04 as 04?
i just went and double checked and confirmed theres nothing there ..also the harness that comes from the ignition coil than goes in 3 directions ...1 goes to camshaft sensor (changed it) 1 goes to exhaust under floorboard front seat ..and the 3rd wire in that harness goes to the sensor i removed ...but like i said looks nothing like what im being shown on any picture at all
4n185185
i also just noticed in another site ..they stated the crankshaft position sensor is below starter in front ...there is a sensor there ..but gonna be darn hard to get outta there lol ...could this be the beast and any suggestions on removing it ....i also read another person had same issue as me ...car wont start ..no spark to ignition coil and they said their timing belt jumped a tooth ...coulkd that do it ...my car started and ran less than a minute and stalled and hasnt started since ..wife said it started rough but we took it as it was cold ..below freezing ...it was sputtering ...than stalled
heres image of where this site says it is ...boy do i hope this is it in 1 way but after looking at it ...omg im gonna have to remove starter to change that ...geesh
http://dodge.justanswer.com/view_ima...101619_ckp.gif
