PLEASE HELP!!! HID PROBLEM!!!
Old 01-05-2008, 02:09 PM
BMRbrnSNRbrd's Avatar
BMRbrnSNRbrd
BMRbrnSNRbrd is offline
Default PLEASE HELP!!! HID PROBLEM!!!
Someone has to know how to fix this problem I'm having with my HID's. I have an '04 Ram QC and recently purchased a bi-xenon HID kit. Well when I installed it the lights would simply blink on for two seconds, off for two seconds, and repeat until I got pissed enough to turn them off. Well I followed some directions regarding wiring in two capacitors (one from high beam power to ground, and one from low beam power to ground) and it still isn't working. Now the headlights, in addition to the blinking, are also going from high to low (or moving the solenoid.) Please look at the video below and someone PLEASE help!!!
http://s269.photobucket.com/albums/j...t=DSCF0930.flv
Old 01-05-2008, 03:11 PM
JCPlowing's Avatar
JCPlowing
JCPlowing is offline
Default RE: PLEASE HELP!!! HID PROBLEM!!!
how much did you pay for those, because i got a set on ebay for 200.00, i plugged them in, and the relay would click on and off, i never was able to get them to work after lots and lots of time and pissed off nights,after i was donemessing with them i was told to get the real HID kit witch costs 1200.00, i have them installed on my truck now, with no problems from the start, if they are the cheap ones good luck, because my buddy has my set that i bought off ebay, and has tried all sorts of things to get them to work and has had no luck what so ever, and i was unable to get my money back in the end so hopfully you will have better luck then i did!!!
But since yours turn on then off try replacing the relay,or jumping past the relaythats all i could think of is the rely is clicking on and off. Hope that helps!!!
Old 01-05-2008, 03:15 PM
bwhite757's Avatar
bwhite757
bwhite757 is offline
Do a search for HID blink or HID problem, there's a fix, a bunch of people have had this problem, actually I think EVERYONE that got HID's from eBay has had it, but there is a way to get them to work, don't worry yet...
Old 01-05-2008, 03:37 PM
BMRbrnSNRbrd
JC Plowing...I don't think I'll EVER spend 1200 on HIDs, seems kind of crazy.
bwhite757...that's the fix I tried, with the capacitors, I'm about to go outside and try some resistors....lets keep our fingers crossed that I don't set something on fire...
Old 06-09-2008, 01:42 AM
vonryanexpress's Avatar
vonryanexpress
vonryanexpress is offline
ANYBODY HAVE A FIX YET!? I have a bi-xenon kit purchased from kbcarstuff.com and I'm getting the blinking pattern and a "lamp out" light in the cab. Please, anybody get at me with a fix!!!
Old 06-09-2008, 11:30 AM
UP_Boilermaker's Avatar
UP_Boilermaker
UP_Boilermaker is offline
I recall reading about this blink problem and a fix for it here. As I remember, it has to do with wiring the marker lights in with the headlights so the system reads the correct resistance or amperage draw. I'll see if I can dig it up.
EDIT: Here's the post I was thinking about. It makes sense to me that it would solve this problem.
https://dodgeforum.com/fb.asp?m=1232379
Old 06-09-2008, 11:41 AM
outlawcrewcab's Avatar
outlawcrewcab
outlawcrewcab is offline
what i did on mine was run a relay. the ballest does not have e-nuff resitance and the switch turns off. simple small 30 amp relay fixed mine with out guessing on resisters
Old 05-10-2009, 05:47 PM
muky's Avatar
muky
muky is offline
Where did you put the relay ??????
Old 05-10-2009, 05:56 PM
sharkhunter10's Avatar
sharkhunter10
sharkhunter10 is offline
here is a diagram of the relay and parts and how they connect my kit came off ebay for 80 and have had no problems.
Old 05-10-2009, 06:00 PM
Alpheus's Avatar
Alpheus
Alpheus is offline
Thats a cool fix. The computer thinks the resistance of the relay is the bulb. I like it...
Quick Reply: PLEASE HELP!!! HID PROBLEM!!!
