'97 Ram 2500 Van Conversion questions
Old 01-05-2008, 09:06 AM
Byounghusband's Avatar
Byounghusband
Byounghusband is offline
Default '97 Ram 2500 Van Conversion questions
Just bought a 1997 Ram 2500 Van conversion. It appears to have been converted by a company called Coachman Vans. I can't seem to find much on the net about this conversion company. Any ideas?
Also, the side mirrors both fold back as you are driving down the road. I have pulled the driver mirror off and tried to put teflon tape around the mirror post to make it a tighter fit in the sleeve that provides friction to keep it in one place. Well it didn't do the trick....[sm=headbang.gif]
Any ideas on a permanent fix?
TIA!!
Bob
Old 01-09-2008, 07:48 AM
austinramman's Avatar
austinramman
austinramman is offline
Default RE: '97 Ram 2500 Van Conversion questions
I had the same problem with my 96 I solved the problem with red RTV.
I would score (roughen up )the plastic outside piece for a better hold.
Old 01-11-2008, 08:40 PM
stev's Avatar
stev
stev is offline
Many of the conversion van compaines went belly up back in the mid 90's.
Try the outfit that purchased out Glaval, Mark III, Tiara, Coachmen, PrimeTime and other van converions. The company is CPC. http://www.cpcparts.com
They purchased out the name brands, tradenames, OEM rights and all of the OEM tooling and inventory.
The only other conversion van company CPC doesn't have is the tried and true StarCraft; The industry leader for the best build conversions.
http://www.starcraftparts.com/php/index.php
Old 01-23-2008, 11:15 AM
Byounghusband
Jeremy,
I think you roughed up the inside of the white plactic sleeve and put the RTV inside it to bind up the mirror post, right?
Quick Reply: '97 Ram 2500 Van Conversion questions
