07 hemi engine oil capacity not 7 qts???
Old 01-02-2008, 09:46 PM
TwoZs's Avatar
TwoZs
TwoZs is offline
Default 07 hemi engine oil capacity not 7 qts???
OK, so here's how the story goes.I had a coupon for a free oil change at the dealer where I bought the truck, so I took it in for the first oil change on Monday. I go the truck back and checked the oil level before I left the dealership...it was about 1 qt over serviced. I talked to the service advisor and he agreed that this was not correct, so he took it back to the tech. 15 minutes later they bring my truck back and say it's good to go. I asked how much they had to take out and he replied "none, I put 7 qts in and that's what the book calls for". So the service advisor says to me that I should drive it for a couple of days and see what it does...WTF. I took it back again today and talked to the service manager and he had them change the oil again because the receipt they gave me also said that they put 5w-30 in it. So 20 minutes later they bring the truck back again and say it all ready, so I check the oil and it's over serviced again by at least 1/2" in the dip stick. End of the story I made them deservice it to the correct level on the dip stick which would put the capacity at about 6 1/4 qts. So, here's my question...should I run it with 7 qts and be over serviced on the dip stick or keep it withinthe correct range on the stick? Has anybody else ran into this problem?
Thanks in advance,
Jim
Old 01-02-2008, 11:11 PM
kx250frider617's Avatar
kx250frider617
kx250frider617 is offline
Default RE: 07 hemi engine oil capacity not 7 qts???
well I would rather have a little too much oil than too little. But you got to remember oil does burn off and down the road you might be putting an extra quart in.
Old 01-02-2008, 11:12 PM
MoparMan61L's Avatar
MoparMan61L
MoparMan61L is offline
We do hemi oil changes all day long at my dealership, we use7 quarts and never have a problem. If they use bulk oil the oil drops may be putting out too much oil when they set it to 7 quarts.
Old 01-02-2008, 11:44 PM
sddunn2's Avatar
sddunn2
sddunn2 is offline
i would think the mark on the dip stick is where you would want the oil to sit after the motor has sat for about 2 min sounds like they are overfilling it to me . I would have asked for it to be drained out and put to the correct level !!
Old 01-03-2008, 01:13 AM
ray97's Avatar
ray97
ray97 is offline
I always thought that running an engine over filledwas worse than running a little low. Anyway that is crazy that the tech told you to drive it like that and lets see in a couple days.
Old 01-03-2008, 01:20 AM
bwhite757's Avatar
bwhite757
bwhite757 is offline
Mine was over full on the lot, but they fixed it before I picked the truck up. Since then I've had Firestone do my oil changes, b/c the manager is a close personalfriend, and he does the work on my truck personally, not to mention their service receipts are second to none. They have filled it to the correct level on all 3 changes. Personally I wouldn't run my truck with too much oil. I'm no expert by any means, but they're has to be a reason dodge (and all other manufacturers) put a FULL mark on the dipstick.
Old 01-03-2008, 01:30 AM
hemiman4ever's Avatar
hemiman4ever
hemiman4ever is offline
remember also that that extra oil could put undue strain and pressure on seals and gaskets causing them to leak.
Old 01-03-2008, 07:34 AM
TwoZs's Avatar
TwoZs
TwoZs is offline
Thanks for the responses. From what I understand overserviced oil could cause extreme oil pressure and foaming. I'm going to keep it in the range on the dip stick, butI wonder if there is any chance that my truck has the wrong dip stick.
Has anybody changed their oil/fliter and used less than 7 qts?
Jim
Old 01-03-2008, 07:53 AM
lilfroger's Avatar
lilfroger
lilfroger is offline
Doesn't the 7 qt INCLUDE what goes in the filter? So if the tech pre-filled the filter and then dropped 7 QT in it it would be over. If the guy goes it the same way every time out of habit then it will be over the second time.
Manual says it takes 7 - I'd have to go w/ that and just assume the monkey doing lube is just that a monkey.
I'll tell ya for sure in a few thousand miles more when the Jeep needs a lube job
Old 01-03-2008, 07:55 AM
#Red's Avatar
#Red
#Red is offline
ORIGINAL: hemiman4ever
Can you say job security?
My oil changes through the dealer are always close to the full mark. Red
Quick Reply: 07 hemi engine oil capacity not 7 qts???
