Rear Wheel Locked Up, Help!!!
Old 01-02-2008, 07:13 PM
espelandt's Avatar
espelandt
espelandt is offline
Default Rear Wheel Locked Up, Help!!!
Hey everyone,
I just pulled my car in the garage this afternoon after being outside in Minnesota for a week. As I hit the brakes stopping in the garage somthing broke. I thought it was the front end but I found nothing. Now when I tried to tkae it out of the garage the drivers side rear wheel is locked up. Its dark and 8 degree outside so I am not going out to check. Anyone got an idea what it could be? Could the hub lock up? Maybe since I was applying the brakes its something with that. Any suggestions as to what I should look at would be appreciated.
Thanks
Old 01-02-2008, 07:46 PM
Yako's Avatar
Yako
Yako is offline
Default RE: Rear Wheel Locked Up, Help!!!
ebrake?
Old 01-02-2008, 09:45 PM
ewetho's Avatar
ewetho
ewetho is offline
Sounds like a drum brake/parkin brake failure.
Need to pull it apart and find out what went wrong.
Old 01-02-2008, 10:56 PM
Izero's Avatar
Izero
Izero is offline
ORIGINAL: ewetho
+1 ^^
Old 01-02-2008, 11:26 PM
spikeymikey87's Avatar
spikeymikey87
spikeymikey87 is offline
yup good luck prying off the drum with the wheel locked lol. i would try to pump the brake a few times, pull the parking brake a few times, and if that doesnt work. bleed the lines so maybe it will loosen up a bit. it will be near impossible to get the drum off with the brake enabled, and if you do manage it, all the parts will blow up in your face and it will not be fun
Old 01-02-2008, 11:50 PM
NHARINTON's Avatar
NHARINTON
NHARINTON is offline
ORIGINAL: spikeymikey87
+1
[/align]
Old 01-03-2008, 09:47 AM
nineball's Avatar
nineball
nineball is offline
yep, same thing happened to my old 98 sport. driver's rear drum locked up tighter than i could believe. good luck.
Old 01-03-2008, 02:36 PM
I own only Dodge's Avatar
I own only Dodge
I own only Dodge is offline
I had similar situation on a FORD I use to own. After I got it apart it turned out that I had blown a wheel cylinder. The piston had come completely out and wedged itself between the cylinder and the pushrod for the pad. Wasnt fun to get it back to normal either. The car was from NewYork and was 5 years old, so it was pretty rusty underneath. The zerk fitting was ceased to the caliper. Played hell gettin it bled.
Old 01-06-2008, 11:45 PM
I own only Dodge
any luck on that wheel?
Quick Reply: Rear Wheel Locked Up, Help!!!
