2004.5 ram 4X4 BALL JOINT REPLACEMENT
Old 12-29-2007, 02:33 PM
sallyman1's Avatar
sallyman1
sallyman1 is offline
Default 2004.5 ram 4X4 BALL JOINT REPLACEMENT
I have a 2004.5 ram short box diesel 4X4. It has 190,000km on it now and front ball joints are shot. Heres my ? I want to order MOOG (with grease fittings ) and do it myself. Question which ones do i order. There are some with different cambers on them .5, 1.5 etc... Which offset or camber do i get. I run a stock lifted truck and normal sized tires. Do a search yourself online for ball joints and youll see what i mean.[/align]
Old 12-29-2007, 02:59 PM
MadMaXxX's Avatar
MadMaXxX
MadMaXxX is offline
Default RE: 2004.5 ram 4X4 BALL JOINT REPLACEMENT
you might want to go and get an alignment check, these SHOULD be free..... and see if your camber is messed up, and by how far... this should give you a better idea of what ball joints you want....
Old 12-30-2007, 02:54 PM
sallyman1's Avatar
sallyman1
If doing the job myself (except wheel allignment) what tools do i need? Parts? Of course ill buy the 2 upper and 2 lower ball joints but what will I need? Will I need any axle seals, Bearings etc...? Can it be done without the tool?
Old 12-30-2007, 09:07 PM
sallyman1's Avatar
sallyman1
has any1s balljoints on a 3rd gen go other than mine? everyone must of had factory greased ball joints.
Quick Reply: 2004.5 ram 4X4 BALL JOINT REPLACEMENT
