Mitusa Fuel System
Old 12-29-2007, 10:37 AM
cmnspwr's Avatar
cmnspwr
cmnspwr is offline
Default Mitusa Fuel System
Anyone know anything about these? They are mechanical, thats all I know about them.
Old 12-29-2007, 10:38 AM
NickBeek's Avatar
NickBeek
NickBeek is offline
Default RE: Mitusa Fuel System
Any links?
Old 12-29-2007, 10:50 AM
triton's Avatar
triton
triton is offline
yeah, it's a pretty quality lift pump that's belt driven and will fuel based on the rpm's. Unlike a electric pump that will continuously pump and return the unused fuel back to the tank.
You can't use them if you have a fluidamper and unless you really need a lot of fuel probably over kill. They'vve been around a long time and only resently have been priced to afford. They used to cost well over 1K
Old 12-29-2007, 10:55 AM
NickBeek's Avatar
NickBeek
NickBeek is offline
Good info Ty. You need to open a performance shop! You know way to much about products not to.
Old 12-29-2007, 10:58 AM
triton's Avatar
triton
triton is offline
well.... Black Patch Diesel I'm a workin on it. :-) When you've done what I have to my truck.... you've hopefully done your homework :-)
here's some item info on the pump....
The MITUSA pump is a synchronous belt driven lift pump that is driven by the motor. The MITUSA has built in redundancy that will automatically switch over to the stock electric lift pump for backup in the unlikely hood of a belt breaking. The pumps volume varies with engine rpm and the regulator pressure is preset at 12 or 16psi per customer request. The kits come complete with all required hoses, fittings and step by step instructions.
Old 12-29-2007, 11:06 AM
NickBeek's Avatar
NickBeek
NickBeek is offline
Nice, keep us posted about your endeavor.
cujo's Avatar
cujo
cujo is offline
ORIGINAL: triton
Cool. Your truck should be one hell of an advertisement.
Quick Reply: Mitusa Fuel System
