1996 Dodge Grand Caravan - s. belt tensioner
Old 12-27-2007, 02:31 PM
wordlarry's Avatar
wordlarry
wordlarry is offline
Default 1996 Dodge Grand Caravan - s. belt tensioner
I think my wife's van needs a new serpentine belt tensioner assembly as her belt just slipped off pulley and its no longer "running true"....
I've gotten new assembly (tensioner base w/ pulley) but cannot gain access to the nut that holds the assembly and its stud in place as its on the back side, top of the 3.8l gas engine.
Any ideas of how to R&R this assembly....
Thanks
Larry
Ga.
Old 12-31-2007, 12:48 AM
dredwin's Avatar
dredwin
dredwin is offline
Default RE: 1996 Dodge Grand Caravan - s. belt tensioner
Larry...I am also in the process of trying to replace my tensioner (and idler pulley since something is squeaking and I figured it was one of the pulley bearings). It wasn't in my Chilton manual and hoped to find the answer on this site.
Here is what I found on WikiAnswers: (it isn't overly helpful but it sounds like you access it from the bottom w/ a 15 MM socket...althought I doubt 2 - 3" extensions is possible...)
How do you replace the Serpentine Belt Tensioner on a 1998 Dodge Caravan?
[/align]
Answer
I have a grand caravan, with a 3.8l engine.
The s-belt slipped off on my way to work, and I went to put pressure on the tensioner, and the bolt snapped in half.
I drove the van up on ramps, and was able to access the 15mm nut on the back of the tensioner. I went to O'Riley auto parts and they showed me the replacment, and then it was a snap. I used a 3/8" ratchet with the 15mm socket and two 3" extensions. It came right off, and the other one went on easily. I had a 2x2 piece of wood that I used to help hold the tensioner in place, while I worked from the back side.
[/align]
V Belts[/align][/ul][/align][/align][/align][/align][/align][/align]
Old 01-01-2008, 11:10 PM
next2pool's Avatar
next2pool
next2pool is offline
I replaced mine from underneath the van and it was quite easy once you feel the nut and get a socket on it--blind. Another way is to remove the alternator, and you can the get at the nut from the top.
Quick Reply: 1996 Dodge Grand Caravan - s. belt tensioner
