Spark Plugs For 4.7
Old 12-27-2007, 02:21 AM
kvsmith2004's Avatar
kvsmith2004
kvsmith2004 is offline
Default Spark Plugs For 4.7
What is the best spark plug to use for a 2004 4.7 ?
Old 12-27-2007, 02:43 AM
kvsmith2004
Default RE: Spark Plugs For 4.7
I am going to put some new plugs in tomorrow and need some advice........
Old 12-27-2007, 07:20 AM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
I'm partial to NGK myself. Won't buy another Champion. Bosch are good, as well.
Old 12-27-2007, 08:15 AM
rammindodge03's Avatar
rammindodge03
rammindodge03 is offline
Autolite Platniums are good too.
Old 12-27-2007, 12:16 PM
wrktruck04's Avatar
wrktruck04
wrktruck04 is offline
im curious to know too as i just got a 04 qc with a 4.7 also and im looking to change em out this weekend.
Old 12-27-2007, 08:19 PM
RaiderJay6's Avatar
RaiderJay6
RaiderJay6 is offline
I used NGK V-power in my 02 4.7 and they were great.
Old 12-27-2007, 08:56 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Jr. Mechanic is offline
NO PLATINUMS! Use the Autolite Copper Core 3923's. They are two heat ranges cooler than the recommended 5224 and are GREAT plugs for how little they cost.
Old 12-28-2007, 12:04 AM
kvsmith2004
I went with the stock champs for now they seem to be working just fine.
Old 12-29-2007, 10:13 AM
DaHipaKea1313's Avatar
DaHipaKea1313
DaHipaKea1313 is offline
How many miles on your ride before you decided to changed them out. Are you changing the wires too??
I see Jr Mechanic says "NO PLATINUMS! Use the Autolite Copper Core 3923's. I did read this in another post, just wondering why the cooler plug, isn't a hotter plug more efficient?
Just asking because I don't know
Old 12-29-2007, 01:06 PM
Jr. Mechanic
ORIGINAL: DaHipaKea1313
People seem to change them out every 20,000-30,000 with cheap plugs. There are no wires on the 4.7 or 3.7, it is a "coil on plug" design. I just put the 3923's in my 06 Dakota 3.7 with 13,000 miles and it made a HUGE difference. Better idle, better mileage, smoother ride, etc. The reason you dont want platinums is because these engines do not seem to like them along with the 3.9, 5.2, and 5.9 LA series blocks, you will lose 20-50 miles per tank. Not sure about the hemi though. The cooler plugs have a shorter tip and prevent pre detonation. It gives it a smoother idle and better mileage like I said before.
Quick Reply: Spark Plugs For 4.7
