Thermostat bolt broke off
Old 12-17-2007, 02:05 PM
lucas3397's Avatar
lucas3397
lucas3397 is offline
Default Thermostat bolt broke off
My thermostat was stuck open so I am in the process of replaing it but while removing the two bolts bolting it to the motor one of them broke off. Anybody got any ideas on how to remove broken off bolts?
Old 12-17-2007, 02:41 PM
98Woo2500's Avatar
98Woo2500
98Woo2500 is offline
Default RE: Thermostat bolt broke off
buy a tap and thread kit. that sux.
Old 12-17-2007, 09:15 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
no worries...
you'll need to drill out the center of the broken bolt, and then use an 'extractor' to remove the remainder. try real hard not to break a drill bit off in the bolt, as that just makes it that much harder. start with a small drill bit, about 1/8 - 3/16. you'll need good, sharp drill bits. don't try to use old worn out junk or you'll be there foreever. if you're lucky you'll get the broken bolt out w/o damaging the original threads. as you drill out the center, the old bolt will sort of give up the fight. but if you do mess them up, then drill/re-tap the next larger size.
another option other than ease-outs is left handed drill bits. but i like std bit and ease-outs better.
http://www.harborfreight.com/cpi/cta...emnumber=40349
http://www.harborfreight.com/cpi/cta...emnumber=38180
Old 12-18-2007, 01:56 AM
lucas3397's Avatar
lucas3397
Thanks for the help, I purchased some of them extractors, My only worries are being able to fit the drill and drill bit down far enough to drill into it straight. Cause if you've ever noticed the thermostat is kinda deep in there, with all that other stuff in the way.
Old 12-18-2007, 07:20 AM
dhvaughan's Avatar
dhvaughan
yep. you'll have to uncover the area as necessary. see the plenum and thermostat diy at the top of the 2nd gen. you may have to remove the alt and/or ac comp to make room. on the ac comp don't take the lines off, just unbolt the mounting and swing it over to passenger side out of the way.
Old 12-18-2007, 09:24 AM
DPR250R's Avatar
DPR250R
DPR250R is offline
ORIGINAL: dhvaughan
Yup.... you'll be amazed at how much that area opens up with all that stuff out of the way.
I would not even attempt to drill out that bolt without doing what dhvaughan mentions.
If you fail... you will be replacing your intake manifold which I just finished doing. It sucked... fought me every step of the way....
Old 12-18-2007, 12:24 PM
lucas3397's Avatar
lucas3397
Alright then, sounds good. Thanks for the insight
Old 12-18-2007, 12:34 PM
arcsum68's Avatar
arcsum68
arcsum68 is offline
I agree, DO NOT try to do that without first removing the ac, alternator, and accessory bracket.
Even IF you were able to drill a straight hole in that bolt, you will need to be careful with the extractor.
They are VERY hard, but that also means they are brittle, make sure you are not wiggling around when you are turning it. You definitely dont want that breaking off in the bolt, cause you wont be able to drill it out.
Just happened to me a few weeks ago when working on my quad, luckly I still had the head of the bolt to work with.
Old 12-18-2007, 01:30 PM
lucas3397's Avatar
lucas3397
Okay so, I have started drilling and it seems that my tools arent what I need. When I drill at thebroke bolt allthe bit does is spin on top of it and do nothing. So what kind of drill bit do I need??
Old 12-18-2007, 02:10 PM
arcsum68's Avatar
arcsum68
arcsum68 is offline
Are the bits new and sharp?
Titanium coated would be nice.
Quick Reply: Thermostat bolt broke off
