wheel hub assembly
Old 12-14-2007, 11:15 AM
justjz's Avatar
justjz
justjz is offline
Default wheel hub assembly
i need to replace the driver side front wheel assembly. the dealer is telling me i need to replace the whole assembly, yet everywhere i check (locally) they tell me they have the bearings only no assembly.
has anyone done this. need some advice.
2004 neon sxt. thanks
Old 12-14-2007, 12:04 PM
dodgedude88's Avatar
dodgedude88
dodgedude88 is offline
Default RE: wheel hub assembly
yeh i had to change out the bearing on the driver side and the control arm on the other, but are you asking if you need to replace the whole metal wheel assembly? if you didnt get in a tiff with a curb like i did hydroplaning at 15 mph with brand new tires with my wheels all the way to the left,lol, you really shouldnt have to replace that metal piece.
Old 12-14-2007, 03:51 PM
justjz's Avatar
justjz
justjz is offline
the dealer said i needed to replace the whole assembly. i'm wondering if i can replace just the bearings. advise.
Old 12-14-2007, 03:59 PM
dodgedude88
yeh i just replaced the bearing and it seemed to be fine although you need to tighten up the cv joint bolt or you will get a grinding noise and a microvibration noise when going 35-60mph. i just tightened up mine to day i sprayed the bolt and washer with silocone spray so it will torque down properly because it does have alot of rust in there. i also had al 2 foot breaker bar attached to the ratchet to help troque down the bolt. the whole reason they want you to replace the whole peice is the bearing is pressed in and its hard to press it in but i got creative.
Old 12-14-2007, 05:02 PM
justjz's Avatar
justjz
justjz is offline
thanks. you've helped me out quite a bit.
Quick Reply: wheel hub assembly
