How do i remove the steering column tilt lever
Old 12-07-2007, 04:18 PM
62hog's Avatar
62hog
62hog is offline
Default How do i remove the steering column tilt lever
How do I remove the steering column tilt lever on an '02 Ram Quad.
Trying to check the wiring for the a/c blower.
Thanks
Old 12-07-2007, 04:58 PM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
Default RE: How do i remove the steering column tilt lever
Seems a strange path. Not sure how removing the tilt control would allow access to the blower wiring. Perhaps someone has had to wrestle with this one before.
Old 12-07-2007, 05:10 PM
62hog's Avatar
62hog
62hog is offline
I am trying to check the wiring at the ignition to see if it is burned.
Old 12-07-2007, 05:12 PM
62hog's Avatar
62hog
62hog is offline
There was a recall on that. The blower has been working more intermittently, and finally quit all the way, since the recall was fixed. I just wanted to see if this was the problem.
Old 04-22-2012, 05:07 PM
dhalsell's Avatar
dhalsell
dhalsell is offline
Default I have had the same blower issues.
I purchased a new ignition switch, I removed the screws to remove the upper and lower cover. I cannot figure out how to remove the tilt wheel lever or lever handle. The rubber paddle type handle is attached to the lever. How do you get the rubber paddle handle off to remove the lever?
Old 04-22-2012, 10:48 PM
kamicrazy99's Avatar
kamicrazy99
kamicrazy99 is offline
Nice ressurection man, but twist and pull on the rubber part, it'll go.... assuming your truck is the same setup as mine?
Quick Reply: How do i remove the steering column tilt lever
