heater smells of gas
Old 12-07-2007, 10:48 AM
onnoff7's Avatar
onnoff7
onnoff7 is offline
Default heater smells of gas
Hi,
Its getting pretty cold now so i have the heater on most the time.
When i first get in it reeks of gas but i dont notice if after 5 mins. so i step out n come back in again the smell is still there.
there might be a simple solution. thanks
Old 12-07-2007, 11:00 AM
Mean Green's Avatar
Mean Green
Mean Green is offline
Default RE: heater smells of gas
Maybe a compression leak from the heaed gasket and a heater core leak?
Old 12-07-2007, 04:59 PM
noregrets's Avatar
noregrets
noregrets is offline
Green is correct if it's coolant you're smelling. However, I had this problem once on another car. It was indeed gas I was smelling. Check for leaks in the fuel lines going into the fuel injectors. That's where my problem was. Nissan replaced mine free of charge due to a recall, but if it's faulty fuel lines, I would suggest calling the corporation and letting them know of the problem. They may replace it for free rather than have you call the feds to report the problem.
Ang
Quick Reply: heater smells of gas
