How Do You Turn Off The Interior Dome Lights
Old 11-30-2007, 02:53 PM
C35L's Avatar
C35L
C35L is offline
Default How Do You Turn Off The Interior Dome Lights
I've been trying to figure out how to turn off the dome light in my charger cause I'm use to not having it on when I open the doors. I prefer it not to come on when I open the doors. Does anyone know how to turn the dome light off? Is there a switch somewhere?
Old 12-01-2007, 06:04 PM
jcyork's Avatar
jcyork
jcyork is offline
Default RE: How Do You Turn Off The Interior Dome Lights
what year charger is it?
Old 12-01-2007, 07:31 PM
C35L's Avatar
C35L
C35L is offline
06 SE
Old 12-02-2007, 01:34 PM
2007DODGERAM's Avatar
2007DODGERAM
2007DODGERAM is offline
Roll down the dim light **** locted next to the headlight ****. If you roll it all the way down the dome light will not come on when you open the door. But if you use your headlight the interior lights (for the radio and the speed controls will be at their darkest. You will need to roll the dim **** back up to make the light in the radio and speed controls bright again.
Old 12-03-2007, 03:57 AM
C35L's Avatar
C35L
C35L is offline
I was cleaning out my car today and I realized about the dim light switch turn it all the way down and it will turn the dome lights off. I'm just so use too using a seperate **** for the dome light switch.
Old 12-07-2007, 10:35 PM
jcyork's Avatar
jcyork
jcyork is offline
you should be able to unbolt the switch in the door jamb and un-plug it. That should keep the dome light off and your dash lights will still be bright, instead of turing the brightness **** all the way down. You also will not have to listen to the anoying beeping sound when the door is open.
Old 10-12-2013, 04:46 AM
h_m_rad's Avatar
h_m_rad
h_m_rad is offline
New Member
Angry not turn off interior lights
I have dodge charger se 2010 & my car not turn off interior lights please Help me
Old 10-12-2013, 04:53 AM
h_m_rad's Avatar
h_m_rad
h_m_rad is offline
New Member
Angry inside lights will not turn off automatically
I have a 2010 Dodge Charger Model SE. I don't know inside lights will not turn off automatically please help me
Old 10-12-2013, 10:39 AM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
The dimmer switch has a detent at the top end that will keep them on at al times, AND a lower detent that will turn them off at all times. Most Dodges are this way.
If they will not shut off, then you may have a door ajar switch issue which means the whole door latch will have to be replaced. Possibly even a broken wire in the door jamb.
AN experiment you can do...close the doors and start the car, turn on the radio (factory), shut the car off and open the door. If the radio does not go off when you open the door then your door ajar switch on drivers front is probably bad.
Old 04-30-2019, 07:48 AM
Jerry Ford's Avatar
Jerry Ford
Jerry Ford is offline
Default Interior Lights
With ignition off, door open, the interior lights remain on for approximately 10 min then will shut off automatically.
Quick Reply: How Do You Turn Off The Interior Dome Lights
