04 dodge ram heater switch problem
Old 11-13-2007, 05:51 PM
dbmstr124's Avatar
dbmstr124
dbmstr124 is offline
Default 04 dodge ram heater switch problem
I have a 2004 Dodge Ram qclb and I cannot get the front defroster to work. I turn the selector switch to it by itself, or the mix with the feet but it still blows no air to my windshield. Is this the switch, or how exactly does it work in my dash to reposition where the air goes? Thank you
Old 11-13-2007, 05:58 PM
hemiyellow's Avatar
hemiyellow
hemiyellow is offline
DC Insider
Default RE: 04 dodge ram heater switch problem
sounds like you got a mode door that is broke
Old 11-14-2007, 12:25 PM
dbmstr124's Avatar
dbmstr124
thanks, is that hard to replace?
Old 11-14-2007, 12:37 PM
tdmopar59's Avatar
tdmopar59
tdmopar59 is offline
depends... its prolly in the dash somewhere...... so PIA if you ask me but i would wait for more opinions....
Old 11-14-2007, 12:42 PM
kregier's Avatar
kregier
kregier is offline
If it is a mode door, you will have to remove the entire dash. You will also probably have to discharge your AC system so you can remove the box that contains the doors and heater core as I think that's where the doors are in, but I'm not sure. It's tons of fun. Aside from the AC discharge/refill, plan to spend a good half day doing this. That's how long it took me when I replaced my heater core.
Old 11-14-2007, 12:51 PM
tdmopar59's Avatar
tdmopar59
couldnt it be some kind of vacume leak too..... ?
Old 11-14-2007, 11:06 PM
dbmstr124's Avatar
dbmstr124
I appreciate all the help. I may take it in and see what it is for sure and then go from there. I'll keep ya'all posted. Thanks again.
Quick Reply: 04 dodge ram heater switch problem
