Which Transmission Fluid - ATF 3 or 4?
Old 11-06-2007, 03:35 PM
Kidd_Funkadelic's Avatar
Kidd_Funkadelic
Kidd_Funkadelic is offline
Default Which Transmission Fluid - ATF 3 or 4?
I'm going to be dropping and replacing my transmission pan since it's rusted and has started leaking. I recently bought my Durango (2000 5.9L R/T) and unfortunately the owners manual is for a 2003 so I can't go by that. I haven't looked at the fill cap to see if it says anything about this but was hoping someone could give me concrete info on which tranny fluid I should be using. I've done a brief bit of online research and have found for Dodge, only use ATF fluid, but that the ATF-4 can be incompatable with some seals on older transmissions.
From: http://www.allpar.com/mopar/transmissions/fluids.html
[blockquote]
If there is a doubt about which grade of ATF to use, follow the owners manual recommendation. AFT+4 in certain specific tests was shown to be incompatible with certain seal material. This incompatibility may cause a premature failure depending on the duty cycle of the vehicle. The fluid will work as intended however, it may cause a seal failure.[/blockquote]
Can someone with a 2000 Durango shed some light?
Thanks!
Old 11-06-2007, 03:40 PM
Kidd_Funkadelic
Default RE: Which Transmission Fluid - ATF 3 or 4?
One more thing- what's the fluid capacity on the tranny when just dropping the pan?
Old 11-06-2007, 06:44 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
It should be ATF+3. ATF+4 also has the additives you seek. I know a lot of people use+4 here were ATF+3 is used. You should need about 12-14 quarts. Make sure that you replace the filter and wipe off the magnet in the bottom of the pan and put it in the new pan. You want a magnet in the bottom. This will help keep medal fragments out of your trany.
Old 11-06-2007, 08:00 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Sixtysixdeuce is offline
That's total capacity, including TC.
Pan drop should be 4-5 qts. Start with 3, check (running in N). If OK, drive it a mile or two and then re-check on level ground. Add as necessary.
The 45RFE takes ATF+4
Old 11-06-2007, 08:38 PM
rabbler's Avatar
rabbler
rabbler is offline
If It's a 5.9L RT I think it has a 46re trans
You can use +3 or +4
I would go with +3 as your only replacing 4-5 quarts
Old 11-07-2007, 11:26 AM
Kensai's Avatar
Kensai
Kensai is offline
I think that only the earlier year model 98-2000 uses the ATF+3 and 2001-2003 uses ATF+4. You can upgrade from 3 to 4 but never downgrade based on what the dealers have said.
I heard that some said that ATF+3 is not synthetic but ATF+4 is full synthetic.
Old 11-07-2007, 11:29 AM
Kidd_Funkadelic
I actually ended up going to the dealership for the parts & fluid before getting any replies and they gave me ATF-4. I figure they should know if that's not OK, so I'll stick with that...
Thanks for the comments.
Quick Reply: Which Transmission Fluid - ATF 3 or 4?
