Transmission Codes P1757 & P1762
Old 11-01-2007, 08:31 PM
ELMO4635's Avatar
ELMO4635
ELMO4635 is offline
Default Transmission Codes P1757 & P1762
My wife's 2000 Durango has aCheck Engine light on... took it to Autozone to have the Codes Checked:
P1757 & P1762 showed up...both dealing with Governer Pressure Sensor issues...
What exactly can I do? Do I have to take it to a Transmission shop?
Thanks,
Eldon
Old 11-03-2007, 10:04 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Default RE: Transmission Codes P1757 & P1762
Remove the transmission pan and replace the governor pressure solenoid and transducer. There are 3 7/16 or 11mm bolt heads and 2 25mm torque bolts, then remove the bracket holding the sensors up to the valve body. also ajust the bands if needed at that time.
Old 10-14-2008, 12:40 AM
techshooter02's Avatar
techshooter02
techshooter02 is offline
does anyone know if this fix works?????
Old 10-14-2008, 07:29 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
It can!
The governor pressure solenoid and transducer are a nusance. They love to get hung up with the slightest fragments.
I second him on this one.
Old 10-18-2008, 12:04 PM
Mean Green's Avatar
Mean Green
Mean Green is offline
Metal shavings can get stuck to these sensors as they are magnetic and can cause everything to go batty. Definitely pull them and replace them.
Old 12-09-2011, 08:34 PM
mikul515's Avatar
mikul515
mikul515 is offline
p1757 code came 0n. now I'm going to fix the solenoid that seems to be the culprit
does anyone know if i can still drive the truck while this code is coming up?? I seem to have lost some power when i first step on the gas(otherwise i can't tell). is there any other name for this part because the children at auto zone can't seem to find this solenoid!!! one kid was insisting on selling me a trailer hitch(because that is what his computer shows) morons!
Old 12-10-2011, 11:13 PM
master tech
I wouldn't untill the problem is repaired.
TurfTaurus318 (05-01-2023)
Old 12-12-2011, 09:25 PM
hydrashocker
i have a 2000 durango 5.9.
P1757 Gov Press above 3 PSI in gear with 0 MPH
What you need is the Governor Assembly. This assembly should come with 1-2 and 3-4 shift solenoids if I remember right. You have a 46RE transmission. You can get it from numerous places including www.rockauto.com and lots of other places. I can't seem to pull up auto zones web site right now to give you the part number.
Old 06-09-2014, 06:55 PM
lifted01ram's Avatar
lifted01ram
lifted01ram is offline
I know I'm a few years late on this response,but just for future reference,this part is called "governor pressure switch" not solenoid.At this time,just in my personal opinion,I would replace the transducer(sensor) as well since you're going to have the governor heat plate off anyway,and they just "pop" out. The 1-2 and 3-4 is not a solenoid,it is in fact the accumulator spring that you're thinking of here.I felt the need to clarify,just in case anybody in the near future has this same problem.Anyhow,I have the same trans(46RE),same problem and it was in fact the pressure switch.But.....at the same time while I was at the valve body,I ended up dropping the valve body,and replacing the TCC/OD(torque convertor clutch/overdrive) solenoid as well as the neutral safety switch,governor pressure switch and transducer,along with accumulator spring.In either case,saying that the clutch wasn't chewed up from driving at high RPM's in 1st gear,this would most definitely solve this problem.I got both P1756 and P1757,and performing this job corrected that issue,and the codes are now cleared and problem solved.Just a little info for future reference is all
Old 06-10-2014, 10:43 AM
mikul515's Avatar
mikul515
mikul515 is offline
Default let me tell you my story...not a good 0ne
Thanks,
Eldon
i had the same trouble codes coming up, ... but since i was broke, i could not fix at thw time, i continued to drive it back and forth to work.. which eventually led me to be st u ck on the side of the road ..... anyway, this was good because it finally made me brake down, and get a new tranny.. ive had no problems since, and that was a few yrs. ago...GOOD LUCK PAL!!!
Quick Reply: Transmission Codes P1757 & P1762
