Diagnostic codes
Old 10-31-2007, 03:01 PM
themouth1's Avatar
themouth1
themouth1 is offline
Default Diagnostic codes
Hi all. I had a check engine light come on. The stealer can't get my truck in for three weeks (welcome to Hawaii). I checked the sticky up top and got the diagnostic codes from my 06 Mega Cab Hemi. I got some codes that aren't listed as well as one that was. The one that was listed is P0571. The others that aren't are:
U110C
U0141
U1411
U110E
U1113
Does anyone know what these mean? Thanks!
Old 10-31-2007, 05:46 PM
hemiyellow's Avatar
hemiyellow
hemiyellow is offline
DC Insider
Default RE: Diagnostic codes
P0571 - Brake Switch 1 Performance
U110C - Lost Fuel Level Message
U0141 - Lost Communication with FCM
U1411 - Implausible Fuel Volume Signal Received
U110E - Lost Ambient Temp Message
U1113 - Lost A/C Pressure Message
Old 10-31-2007, 05:47 PM
kenihemi's Avatar
kenihemi
kenihemi is offline
P0571 is a brake switch No. 1 Performance fault. Those other codes, I don't have a clue, you need P codes.
Old 10-31-2007, 09:37 PM
themouth1's Avatar
themouth1
So what would cause the check engine light? Why all the codes all the sudden? This truck has 6000 miles on it. I never had this issue with my 04 Hemi...
Old 10-31-2007, 09:58 PM
buzzard217's Avatar
buzzard217
buzzard217 is offline
Sometimes you can get crazy codes from the battery being weak. Also if the IOD fuse under the hood is not pushed in good crazy codes could appear. I would check the state of the battery. They can go bad after sitting on the lot until they are sold.
Old 10-31-2007, 10:00 PM
themouth1's Avatar
themouth1
Thanks! I will take a look.
Old 10-31-2007, 10:15 PM
buzzard217's Avatar
buzzard217
by the way P codes are for powertrain issues. U codes are body modles such as CCN, ORC, HSM, so on and so forth.
Old 10-31-2007, 10:26 PM
hemiyellow's Avatar
hemiyellow
DC Insider
yeah i got a whole database of these codes from work...every code (P, U, & C) all up through 2009 1/2 lol
Old 10-31-2007, 10:38 PM
buzzard217's Avatar
buzzard217
ORIGINAL: kenihemi
without any offense intended to kenihemi I was just tring to clarify what the prefix on a SAE code means
Old 11-01-2007, 05:35 AM
HankL's Avatar
HankL
HankL is offline
SnapOn's info on OBD code basics:
http://www.snapon.com/scanlines/sl701p3.asp
Jeep owners put this impressive webpage together with pictures:
http://wjjeeps.com/faultcodes.htm
Quick Reply: Diagnostic codes
