heater blowing cool air
Old 10-28-2007, 03:47 PM
gopurs65's Avatar
gopurs65
gopurs65 is offline
Default heater blowing cool air
I have a 2000 dodge durango and the heater quit blowing hot air. The thermostat is working normal, radiator is normal, felt both hoses going in and coming out of the heater core and they are both hot and not leaking inside.Everything seems to be working like it should but will not blow hot air. Can someone PLEASE help . Thanks in advance.
Old 10-28-2007, 06:21 PM
Mean Green's Avatar
Mean Green
Mean Green is offline
Default RE: heater blowing cool air
You probably just need to do a reverse flush on the heater core. 1/16" of scale buildupis like 2" of metal as far as heat transfer goes.
Old 10-29-2007, 03:29 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
damn, i was going to be wise *** and tell him to turn the A/C off, damn it
Old 10-30-2007, 10:22 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Did you ck the acc heater pump on the right side of fender well. next to the firewall.
Old 10-30-2007, 10:42 AM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
I likedshrpshtr answer.
Reverse flush the heater core. Search the forum in the Durango 1st generation for great information on this very issue.
Quick Reply: heater blowing cool air
