4X4 Low - How to engage
Old 10-23-2007, 10:42 PM
Master Baiter's Avatar
Master Baiter
Master Baiter is offline
Default RE: 4X4 Low - How to engage
Maybe it wears the more times you use it thus less grinding???
Old 10-23-2007, 10:44 PM
FroneDaddy's Avatar
FroneDaddy
FroneDaddy is offline
My '97 grinded like crazy, had to shut it down. My '03 has the electronic shifter, I don't have to shut if off anymore, just have to make sure tranny is in neutral and the clutch is in when I shift to 4 low
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
It's the act of getting the gears closer to the same speed. kind of like shifting a tranny that has bad syncros...
Old 10-23-2007, 10:45 PM
Tommygunz's Avatar
Tommygunz
Tommygunz is offline
Will have to remember and try it when I need it, maybe I will go play with it this weekend.
Old 10-24-2007, 01:12 AM
BiggBlu601's Avatar
BiggBlu601
BiggBlu601 is offline
when i got my 07 i was playin with the 4wd. just shifted it into neutral put the parking brake on and turned the button over to 4lo. heard a clunk and it was engaged. did the same back to 2wd and it shifted right back. didnt seem to hurt nothing. it did the same thing in my 05 z71 when i shifted into 4lo.
Old 10-24-2007, 03:15 AM
Little Foot's Avatar
Little Foot
Little Foot is offline
master baiter, do you have the shifter on the floor or are you on of those push button 4x4 people. I believe in 06 they offer both. The only time I had mine grind was when I was on Ice and didn't fully apply the brake while in 4 high and there was a tire spinning when jammed into 4 low. Like mentioned above make sure that you are in neutral with engine at idle and you should be fine.
Old 10-24-2007, 07:08 AM
Bigriver's Avatar
Bigriver
Bigriver is offline
I'm assuming that everyone here has manual transmissons. As with my auto, shifting from 2Hi to 4 Hi, just roll slowly in driveand turn the dial. I'm not sure what the maximun speed at which this can be accomplished, perhaps as much as 55 mph.
To shift into 4Low from there, I shift the transmisson into nutreal while still rolling at just under 5 mph and turn the dial again into 4Low. There is usually a slight " clunck ", but I remember reading in the manual that it's normal to hear that.
I never really use the 4WD that often, but on occasion, shift into the gears just to lubricate the seals and work the transfer case.
Old 10-24-2007, 07:20 AM
Drew's Avatar
Drew
Drew is offline
hum. . .Ive never had this grinding your talking about. . .just a good clunk when I push the lever from N to 4lo.
Old 10-24-2007, 07:44 AM
cujo's Avatar
cujo
cujo is offline
I think those of us who grind have the automatic trans and the floor mounted manual transfer case shifter. Never had a truck grind going into 4 low with a manual tranny.
Old 10-24-2007, 03:22 PM
Master Baiter
Yeah, sorry bout that I should have clarified. It's an auto tranny with a manual transfer case (on the floor, not electronic or vacuum). My ford had an electronicknob you turn, which made it nice, no noises, but it had to be working in order to go into 4 wd!
Quick Reply: 4X4 Low - How to engage
