P0551 Power Steering Pressure Sensor Circuit Range
Old 10-15-2007, 05:47 PM
redskinz56's Avatar
redskinz56
redskinz56 is offline
Default P0551 Power Steering Pressure Sensor Circuit Range
How do I fix this problem.
I have a check engine light for
P0551 Power Steering Pressure Sensor Circuit Range/Performance
Old 10-15-2007, 09:53 PM
Mat00ES's Avatar
Mat00ES
Mat00ES is offline
Default RE: P0551 Power Steering Pressure Sensor Circuit Range
Replace the sensor, its on the driver side, just follow the hoses. I paid like $30 for it at autozone, just be careful of the steering fluid coming out.
Mat
Old 03-05-2013, 02:43 PM
bstrada's Avatar
bstrada
bstrada is offline
Default power steering pressure switch
What does the power steering switch on the pressure line do..1997 dakota 2.5 motor Thank you
Old 03-05-2013, 06:04 PM
TejasMtnBiker's Avatar
TejasMtnBiker
TejasMtnBiker is offline
same thing, I had the 96 dak with a 2.5, it just makes the engine speed up when pressure is used (turning back an forth etc)
That's one truck I should'a never ever got rid of......
Quick Reply: P0551 Power Steering Pressure Sensor Circuit Range
