Factory engine specs
Old 10-06-2007, 02:44 PM
chris_wallin77's Avatar
chris_wallin77
chris_wallin77 is offline
Default Factory engine specs
Hi
I've been looking all over the web for a the engine specs of a 1990 4x4 Dodge B350 with the 360 enginge, and any other information would be great as well, from the looks of it Dodge didn't make the B350 with 4x4 that year... and I know that's not true.
//Chris
Old 10-07-2007, 03:12 PM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
Default RE: Factory engine specs
The engine specs. will be the same as the 2wd version.
Old 10-07-2007, 04:46 PM
IGadget's Avatar
IGadget
IGadget is offline
Dodge themselves never made a 4x4 van at all. That doesnt mean you dont have one. that means that your chassis may have been sent to a company like Quigley Automotive, they put in the 4x4 drive train, and then sent it back to dodge for the body to be applied. Another method could be if somone did a body swap the only way to verify that would be to check that the vin on the engine matches the body.In the case of a Quigly conversion the engine and the body vin will match.
If you have a Quigley conversion, they generally hold a premium so you got a deal. Quigly stopped converting dodges in 94, the stated reason at the time was because of how Dodge placed the saddle gas tank made the conversion impossible.
Old 10-07-2007, 05:16 PM
chris_wallin77
and what are those specs... in torque and hp, can't find specs that are "factory" so to say.
//Chris
Old 10-07-2007, 05:55 PM
alloro's Avatar
alloro
alloro is offline
Here's the best I can find.
Old 10-07-2007, 06:20 PM
chris_wallin77
Thanks... much better than I could find
Quick Reply: Factory engine specs
