Avenger Battery Location
Old 09-24-2007, 07:37 PM
futil's Avatar
futil
futil is offline
Default Avenger Battery Location
Hey everyone.. Im new to the forums.. I just purchased a black 08 Dodge Avengerand I am waiting for it to arrive at the dealershipbut in the meantime I was poking around on the other Avengers on the lot, andpopped the hood on one.. after spendinga whilesearching for the battery I located it under the fuse block on the driver side. (I never had to search for a battery on a car before)
I was curious if anyone knows what the proper procedure is to remove the Battery to replace it? Should I be removing parts from under the car to get to it or pull out the fuse block and start unbolting stuff heading down?
Is the battery removal easier than it looks? because from what I have seen it looks like a lot of work just to get to it which in my opinion isnt really a great design move since the battery will probably need to be replaced eventually and is frequently done by the car owner.
I probably shouldnt be posting this question until I get thecar cause its probably in the manual or something like that but I am curious whats involved.
Thanks
Old 09-24-2007, 07:49 PM
regandon's Avatar
regandon
regandon is offline
Default RE: Avenger Battery Location
From page 379 of the owners manual.
To access the battery, turn the wheel fully to the right and remove the inner fender shield.
Old 09-24-2007, 08:11 PM
futil's Avatar
futil
futil is offline
Thank you
I had a feeling it was inthe manualsomewhere but the curiousity was eating at me and I just couldnt wait to getmy Avenger to find out..
Thanks again
Quick Reply: Avenger Battery Location
