97 1500 won't turn over
Old 09-22-2007, 01:57 AM
just4today010201's Avatar
just4today010201
just4today010201 is offline
Default 97 1500 won't turn over
New to the forums. Have a 97 1500 4x4 w/ 90k miles. Was in and out of it all day....got back in and it won't turn over. Has power to electrics..headlights arn't dimming when I turn the key. Tapped on starter to see if that might help. Havn't had any sign that the starter was going though. Any ideas?
Old 09-22-2007, 10:36 AM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
Default RE: 97 1500 won't turn over
what noise does it make when you try to turn it over? Clicks, or normal sound just doesn't light up?
Also, listen carefully for the whine of the fuel pump when you go to start up. No pump, no fuel
Old 09-22-2007, 11:39 AM
just4today010201
doesn't make any sound at all. Hope that helps
Old 09-22-2007, 04:00 PM
micah97's Avatar
micah97
micah97 is offline
I had the same problem a couple of times. One time it was the starter. There was a funny electrical smell around the truck. I crawled under and checked the starter and sure enough, it was toast. Does it have an odd smell? The other time came after I had done some work in the engine bay and interior. I went through and reseated all the connectors I came in contact with, and reseated all the fuzes. It cranked fine after that. I'd check all the fuzes in the cab and engine bay.
Old 09-22-2007, 08:33 PM
aim4squirrels
Just nothing? Probably the starter. Starters sometimes don't give any indication that they're going out, they just quit.
Did you hear the fuel pump? Sometimes it's easier to hear if you turn it to start but don't actually kick the engine over, but since you've got nothing, I wouldn't think it was that, as a working starter would crank the engine, but no fuel would just keep it from lighting up.
Old 09-22-2007, 10:47 PM
Chopper1's Avatar
Chopper1
Chopper1 is offline
A guy I work with just had a similar issue. He replaced the battery and the starter with no luck. Ended up being a fuse in the truck. Don't know which one but worth checking them all......
Old 09-22-2007, 11:04 PM
priest1981's Avatar
priest1981
priest1981 is offline
Is it a manual? If so you may have a problem with the clutch safety switch.
Will
Old 09-23-2007, 12:21 AM
just4today010201
Checked and rechecked all the fuses to no avail. Went ahead and took the starter off and will have it tested tomorrow.
Quick Reply: 97 1500 won't turn over
