Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
front end alignment???
Old 09-10-2007, 05:36 PM
houndog's Avatar
houndog
houndog is offline
Default front end alignment???
An alignment shop told me the Intrepid doesn't need alignment. My '99is pulling right and he said the tie rods could be bad. Anyone care to elaborate on this?? Thanks....Jim
Old 09-10-2007, 11:33 PM
kurts2's Avatar
kurts2
kurts2 is offline
Default RE: front end alignment???
The rods could be bad, or somthing knocked (or bent) or loosened etc. As with any car, of course you can align it! What he probaly ment was there must be somthing wrong, but to assume bad tie rod ends with no looseness or clunk and not put on a lift is nuts. I'd go elsewhere!
Old 09-11-2007, 02:52 PM
houndog's Avatar
houndog
houndog is offline
Thanks, I've found someone else..jc
Old 08-27-2011, 11:30 AM
wes2760's Avatar
wes2760
wes2760 is offline
my 96 intrepid makes a clunking sound when turning the wheel I was told it was the subframe bushings I replaced these also steering was sloppy I replaced drivers side rack and pinion bushings funny I could not find ones for the passenger side tho anyway still clunking any suggestions?
Quick Reply: front end alignment???
