transmission in-line check valve?
Old 09-07-2007, 01:59 PM
wildwolf59's Avatar
wildwolf59
wildwolf59 is offline
Default transmission in-line check valve?
having problems with truck shifting right so i wanted to check the in-line check valve before i do anything else but i cant find it on my lines....is there a check valve on all these trucks or not and if so where is it???
Old 09-07-2007, 04:18 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
Default RE: transmission in-line check valve?
its under the hood, at the end of the hard lines, at the passenger side frame rail. its on the hot/pressure line. its a little thing, only about an inch long, and screwed into the end of the hard line.
Old 09-08-2007, 02:04 AM
rabbler's Avatar
rabbler
rabbler is offline
The check valve is shown in the third pic of this thread
https://dodgeforum.com/m_957657/tm.htm
Old 09-08-2007, 05:26 PM
IndyRamMan's Avatar
IndyRamMan
IndyRamMan is offline
ORIGINAL: rabbler
its the more copper looking "fitting" than the others...also it has 2 small hose clamps on the right side of it, incase you couldnt find it in the mess.
Old 09-08-2007, 10:13 PM
wildwolf59's Avatar
wildwolf59
Ithought that was it but wasnt for sure...thanx a lot indyramman!!!...now will take it out and see if it is sticking!!!!
Old 09-08-2007, 10:26 PM
rabbler's Avatar
rabbler
rabbler is offline
It's a very strong check valve, it think its takes 20-30 psi to open it. too strong in my opinion
Quick Reply: transmission in-line check valve?
