Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
help remove alternator from 1995 dodge stealth
Old 09-05-2007, 09:47 PM
WESTCOASTPOPS's Avatar
WESTCOASTPOPS
WESTCOASTPOPS is offline
Default help remove alternator from 1995 dodge stealth
does anyone know the best way to remove an alternator from a 1995 dodge stealth-3.0 liter-v6-sohc-automatic trans..
Old 09-05-2007, 10:35 PM
t4dude's Avatar
t4dude
t4dude is offline
Default RE: help remove alternator from 1995 dodge stealth
Take out the radiator, the driverside tire and the cover underneath that protecs the engine. Google search it and it has a complete directions and photos
Old 09-06-2007, 09:28 AM
thestealth's Avatar
thestealth
thestealth is offline
I was able to remove my alternator without removing the radiator. I just removed the fan on that side. I'd place a piece of cardboard against the radiator so you don't bang up the fins. It takes some manuevering, but it can be done. Everything else T4 said is pretty much right on. Remove the wheel, the plastic cladding, and start unbolting stuff. Search Stealth316.com for detailed instructions.
Old 09-05-2009, 09:34 AM
perez042001's Avatar
perez042001
perez042001 is offline
Exclamation Alternator
The dude is talking about a sohc , NOT a dohc, there is a difference, The SOHC the alternator is inthe back of the enge, and the DOHC THE ALTERNATOR the front, for SOHCyou DO NOT HAVE TO PULL THE RADIATOR
Old 09-05-2009, 09:35 AM
perez042001
Different engines sohc and dohc
Old 06-25-2011, 05:38 PM
orrbit1's Avatar
orrbit1
orrbit1 is offline
To remove alternator from 1995 dodge stealth sohc you need to remove the coil and throttle cable guide from the intake manifold. Then remove the heat shield from the exaust manifold this will give you just enough room to pull it out through the top. The fun part will be putting it back in. I just finished removing mine and hope this helps someone so they won't have to pay some random dodge mechanic 18 dollars for an answer.
Quick Reply: help remove alternator from 1995 dodge stealth
